RMSK, Inc.
Results 1 to 6 of 6
Thread: Test/review of GTF TR16340 2800mAh (White)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/review of GTF TR16340 2800mAh (White)
    Official specifications:
    • 100% brand new GTL123A 3.7V 2800mAh rechargeable batteries
    • Capacity: 2800mAh
    • Voltage: 3.7V
    • Chemistry: Li-ion
    • Recharge: up to 1000 cycles
    The latest scam in high capacity 16340 batteries.
    They are a bit below rated capacity, actual capacity is 250mAh to 300mAh at low load. they do not support moderate or higher loads.
    They do not contain energy enough to get warm.
    Conclusion
    These cells may be cheap, but compare to what you get they are way to expensive. Any decent cell will have about double capacity and handle higher load much better.
    I will rate them as bad
    Notes and links
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Comparison to other LiIon batteries
    My website with battery, charger, usb reviews, comparisons & information: lygte-info.
    Latest addition is multimeter reviews
    Banned
    Aug 2013
    Valley Forge, Pa.
    Default Re: Test/review of GTF TR16340 2800mAh (White)
    Thanks HKJ!!
    LOL!!! 2800mAh! At first look I said,,what??,,,maybe they mean a 26650!
    To to think that the average Joe,,,,,,actually waaay below average Joe w/ fall for that!
    2800 mah rated, 285 mah tested.
    Obviously they misplaced a decimal point.
    Flashaholic* fivemega's Avatar
    Jan 2003
    California
    These batteries deserve the name: Get The F
    Maybe the reason that capacity was not measured properly is the fact, that testing equipment does not follows specifications defined by battery manufacturer, as it was in case with 2700mAh AA batteries?
    Enlightened Bugdozer's Avatar
    Nov 2016
    Los Angeles
    Should have been called WTF TR16340.
