NITECORE -- Keep Innovating
Results 1 to 4 of 4
Thread: Troubleshooting trailer turn signals
    Default Troubleshooting trailer turn signals
    I have a Ford Ranger with a factory 4 pin connector. I used to pull a popup camper, so it plugs into a 7 pin connector. I think it's functioning properly.
    I've assembled a Harbor Freight utility trailer. The lights sort of work, but there's an issue.
    Symptoms: If if just use the turn signals they won't work. If I turn on the parking lights on the truck, then all the lights on the trailer come on and the turn signals function properly.
    Ideas?
    Moderator Alaric Darconville's Avatar
    Sep 2001
    Stillwater, America
    Default Re: Troubleshooting trailer turn signals
    Quote Originally Posted by PiperBob View Post
    "Hazard Fraught"
    Does the stop lamp function work normally?
    I'd check the grounds-- make sure the trailer's lamp assemblies actually connect to a ground wire-- sometimes to save costs a lamp assembly might be connected to the trailer frame instead of to a ground wire.
    Sorry for the delay in responding. A giant oak fell in our yard so I haven't been able to get back to the trailer until yesterday (busy chopping wood).
    It's all working fine now, so I can only assume I didn't have the plug in well enough or something. I'll put some silicon grease on the pins.
    Sep 2001
    Stillwater, America
    At least it didn't smoosh the truck or trailer.
    First troubleshooting step is just check all the connections. Unplug/replug the usual connectors and such.
