Klarus
Results 1 to 17 of 17
Thread: Test/review of Shockli IMR26650 5500mAh (Black) 2017
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/review of Shockli IMR26650 5500mAh (Black) 2017
    Official specifications:
    • Nominal voltage: 3.7V
    • Nominal capacity: 5500mAh
    • Charge voltage: 4.20V +/-0.5V
    • Standard charge current: 0.5A
    • Maximum Charge current: 2A
    • Maximum continuous discharge: 20A
    • Maximum pulse discharge: 30A
    A high current and high capacity 26650 cell.
    The two cells are very well matched and as usual I test them a bit above specifications. They handled 20A fine, but did not like 30A continuous, it blew a fuse inside both cells, preventing me from doing the rest of the tests.
    AT 20A they get rather hot, I measured about 78°C.
    At 30A they reached 86°C before the fuse blew.
    Conclusion
    The performance of these cells looks very good and I will look on it as an advantage that they blew a fuse when overloaded (Instead of blowing up).
    For vapers that want to use 30A, this fuse is no problem, I draw 30A for about 8 minutes continuous before it blew.
    Notes and links
    The battery was supplied by shockli.com for review.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Compare to 18650 and other batteries
    Compare to 26650 and other batteries
    My website with battery, charger, usb reviews, comparisons & information: lygte-info.
    Latest addition is multimeter reviews
    Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Default Re: Test/review of Shockli IMR26650 5500mAh (Black) 2017
    Yay! A cell that actually exceeds its label specs!
    Thanks.
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
    Flashaholic* MAD777's Avatar
    Jul 2015
    South Florida
    Wow! They hit it out of the park with this one! Too bad we cannot buy this in the USA.
    Nov 2013
    Idaho, USA
    Perhaps we will soon see a 26650 that can provide a true 6Ah at 10A discharge? A google search turns up a lot of hits, but none look legitimate.
    Banned
    Aug 2013
    Valley Forge, Pa.
    Thanks for the review HKJ!
    Amazing capacity!
    Wait until he tests the NEW High Drain King!!,,,,,,,,,,,,,Ijoy INR 26650 which can be bought in this country by supposedly only One dealer,,,my hometown dealer!
    Oct 2013
    USA
    Quote Originally Posted by MAD777 View Post
    Maybe you can get them from Shockli's German distributor MSITC, but they are expensive there: 16.90 ($18.18)
    Oct 2012
    Norcal
    Quote Originally Posted by Gauss163 View Post
    Not the same thing. Those cells are only rated at 5000mAH.
    Oct 2013
    USA
    ^^^ Right, that's why I said "maybe". Since they are Shockli's official distributor, they'll probably stock the 5500mAh version too, but they will likely be expensive - just like the linked 5000mAh version.
    Jul 2015
    South Florida
    I'm hoping Richard at MtnElectronics stocks the 5500. They do carry Shockli brand.
    I am attempting to do a LiFePo4 4x32650 5000mAhr (2P2S) 6C Maglite Mod (I already own the cells from a past ammo can 5/6/12V Power Pack project that have been replaced with 20Ahr Prismatics so I won't be taking a financial risk) If the dropout of the board and wiring is too high to give 6.13v at the 3xXHP50s and I'm not pleased with what power I do get, my fallback plan is to switch to some high end IMR26s or 32s instead. I hope we can get these in the US.
    Mike
    No luck finding this cell anywhere yet. When they eventually appear they should sell like hotcakes.
    HKJ
    "I want to see the target, not the beam" -Zak
    My lights
    Jul 2015
    South Florida
    We should all email Richard at MtnElectronics (they carry Shockli) to let him know our interest. I would commit to ordering a half dozen.
    Here is the "contact us" page from their website....
    http://www.mtnelectronics.com/index....mation/contact
    I contacted him.. he havent email me back.
    Flashaholic* vadimax's Avatar
    Dec 2015
    Vilnius, Lithuania
    A fuse?! What a stupid idea... A cell is rendered garbage when it is still fully functional inside. With its projected price tag we could expect a properly working (recoverable) protective circuit.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by vadimax View Post
    Not really when you want something with very low resistance, that can prevent the cell from explode.
    The other possibility would be a PTC, but it might add more resistance and they do not return exactly to the initial condition when triggered.
    Electronic circuit makes the battery longer, is not good at high current* and also add some resistance.
    *I am going to look at some batteries with an improved electronic circuit that is better at high current in the near future.
    Nov 2013
    Idaho, USA
    He started stocking them, but it looks like he sold out the inventory very quickly.
    Nov 2013
    Idaho, USA
    Mooch is late to the party with his test:
    https://www.e-cigarette-forum.com/fo...er-65w.824465/
    At 10A load down to 2.8V, he measured a capacity of 5471 mAh, less than HKJ measured on his samples
