Arizona_Mike
- Joined
- May 4, 2015
- Messages
- 117
I have some laptop pull 4.3v cells (LG LGABC1865) and I decided to try the "hidden" 4.35v setting on my Opus BT-C3100 V2.2 charger. The spec sheet says not to go above 4.30 +/- 0.03v but the danger of charging is heat (after there is no more Li to move to the resistance shoots up). I charged at 500mA and for the first few tenths of a volt above 4.2 it was still allowing high 400s of mA demonstrating Li was moving. By the time I hit 4.33v current was down to 150mA or less and the cells were cool to the touch. Eventually they terminate for low current at around 4.33 or 4.34v. I'm not at all worried about damaging them with the extra 0.05v (and besides they are free laptop pulls).
I have 8 cells 2800mAh cells that tested out at about 2.1k from 4.2v down to 2.8v. The first 4 tested out at 2.5k from 4.3 to 2.8v (a 14% improvement on the raw numbers before rounding). The 2nd 4 are testing as I type this.
So is it worth it? I think it is.
Mike
Mike
