Led Astray
I've got a pair of protected Olight 3400mAH 18650s, and am trying to charge one that has been lying around for a few months unused.
When I put it into my i4 the yellow lights blink as expected, starting with just one, then a few seconds later it either jumps straight to 3 illuminated indicating charging over, or flashes on 2 for a while (and it can be quite a while) before going to 3.
My DMM reads 3.8V which seems to be the limit. I have tried multiple times but once 3 lights are showing I have to leave the battery for a while before trying again or the charger jumps straight to 3 lights. It can take a dozen tries before it looks to be charging normally however it always terminates early.
I tried on my Li100 and it goes straight to termination as well.
The other Olight performs as expected in the i4, i.e. charges to 4.2V.
I suspect therefore that the protection circuit is playing up but don't know how to reset it and can't find any info other than resetting in the case of the circuit tripping due to low-voltage, which isn't the case here. I always store my spares at 3.6V or 3.7V, and this one was no exception.
Any ideas?
Any ideas?
