Rofis New Variable -Output Angle Light TR 15 is launched
rofisbenny
Hello Rofis fans,
We are pleased to introduce the variable –output angle light TR 15 to you all.The TR 15 is an adjustable -head flashlight with a beam angle of up to 90 degrees,which has ultra compact and lightweight (diameter 22mm, length 97.5mm,net weight 62g).The utilization of CREE XP-L HI V3 LED delivers maximum output of up to700 lumens and reaches a maximum beam distance of 113 meters. The TR15 has three brightness levels and three special modes. The light is compatible with AA size rechargeable or standard 14500 battery types.
Following is the detailed specification of TR15:
Features
1. Adjustable-head flashlight, multi-functional usages
2. Tail built-in magnet
3. Utilizes a CREE XP-L HI V3 LED
4. Maximum output of up to 700 lumens
5. Boasts a peak beam intensity of 3175 cd and a throw distance of up to 113 meters
6. Innovative single button offers access to three brightness levels and three special modes
7. High efficiency constant current circuit provides max runtime of 82 hours
8.Integrated power indicator light to remind the user the battery power will close to depletion
9. Memorized function ability
10. Direct access to moon mode
11. Ultra compact and lightweight (diameter 22mm, length 97.5mm),net weight 62g
Switch incorporates a specially designed lock function to prevent accidental illumination.
12. Reverse polarity protection prevents damage from incorrectly inserted batteries
13.Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
14. A micro-textured reflector offers wide angle lighting
15. Waterproof in accordance to IPX-8 (two meters submersible)
16. Impact resistant to 1 meter
17. Tail stand capability
18.With locating function,the flicking red light in the dark can help to detect flashlight's position easily
Length: 97.5mm (2.93'')
Diameter: 22mm (0.86'')
Weight: 62gram (2.19oz.)
Accessories
Clip, Lanyard, Spare O-ring
View attachment 5501View attachment 5502View attachment 5503View attachment 5504
Thank you for reading. Welcome to leave your valuable opinions and suggestions. If you need any information, please feel free to contact us: [email protected] .
