Miboxer
Results 1 to 2 of 2
Thread: 18650 charging with IMAX b6(fake). Discharge voltage incorrect.
    Unenlightened
    May 2017
    Default 18650 charging with IMAX b6(fake). Discharge voltage incorrect.
    Hi everyone. This is my first post.
    I just wanted ask about IMAX b6(fake).
    When I discharging 18650 battery, the voltage on IMAX charger isn't correct. And then it leaves battery on 3.5+ volts when fully discharge (battery internal resistance is low).
    But menu it says 3.0v. Similar with charging. It overcharges battery to 4.21-4.22.
    Can someone suggest something?
    Maybe cable problem? Resistance? I don't know.
    Default Re: 18650 charging with IMAX b6(fake). Discharge voltage incorrect.
    The original b6 can you calibrate voltage menu
