NEXTORCH
Results 1 to 17 of 17
Thread: 10g only AAA keychain flashlight 120 lumens pocket mini LED torch
    Default 10g only AAA keychain flashlight 120 lumens pocket mini LED torch
    Tank007 E13 is a super mini led flashlight, it weighs only 10g. To those whol love keychain flashlight, this one is a good choice.
    E13 is a portable mini led flashlight powered by 1*aaa battery, which weighs only 10g, very easy to carry
    Simple but reliable rotatable head switch
    One mode design, easy to operate
    Pocket clip included, convenient to carry and use.
    LED SPECIFICATIONS:
    Brand & Model: LED
    LED Lifespan: above 50,000 hours
    Max Brightness: 120 lumens
    Throw Beam: 80 m
    CIRCUIT SPECIFICATIONS:
    Input Voltage:0.8-3.7V
    Output Level: one mode
    BATTERY SPECIFICATIONS:
    Power Source: 1*AAA
    Burn Time: high light- 0.6hours;
    PHYSICAL SPECIFICATIONS:
    Size(cm): 6.4.0(length)* 1.28(body diameter) *1.4(head)
    Weight(g): 10(excluding batteries including pocket clip)
    Switch: Head rotary switch
    Material: made of durable aircraft-grade aluminum T6061
    Reflector: High temperature vacuum coated aluminum mirror reflector
    Lens: toughened glass lens
    Treatment: Anodized anti-abrasive finish
    Waterproof: IPX-8
    Anti dropping height: 1.5 m
    Color: black,
    Sounds good? leave your commment below now!
    Prodcut page: http://www.tank007.com/product/e13-mini-portable-flashlight/
    Enlightened DRAWs's Avatar
    Jun 2016
    Indonesia
    Default Re: 10g only AAA keychain flashlight 120 lumens pocket mini LED torch
    that is a sweet flashlight, but no tailstand
    Quote Originally Posted by DRAWs View Post
    Sorry about that. But it can stand on head
    Price update: $14.5 inclduing shipping. Cheaper for bulk order.
    http://www.tank007store.com/tank007-...umen-one-mode/
    I think the price is a little higher, though the flashlight looks good.
    Quote Originally Posted by KatherineLee View Post
    I am sorry to hear that but what price is good for this flashlight? We always take quality to first place when we make the flashlight, that's why this flashlight prices 14.5 USD
    In some shop the E09 is 15 USD or so, which is better than E13 in my opinion. I think you should consider the price again.
    But in some online shops, your E09 is around 15USD only, which has three control modes.
    Thanks for your feedback. We will consider the price again.
    this_is_nascar's Avatar
    Mar 2002
    Gloucester, New Jersey
    Just barely a half hour runtime? Why would I want to EDC this light?
    Am I reading the specs wrong?
    ... it's not what you take when you leave this world behind you, It's what you leave behind you when you go.
    Quote Originally Posted by this_is_nascar View Post
    You are Not wrong. But most AAA flashlights can only last about half an hour at high light mode, am I right?
    Mar 2002
    Quote Originally Posted by Tank007torch View Post
    SL Microstream will run for a couple hours, for example. I just don't see the usefulness of a light that will run for only a half hour. Regardless of its size, why would anyone want to waste that pocket space or keychain space when they have much better offerings available.
    It's your design that you want, so good for you. I wish you luck. For me, I wouldn't even consider looking at this light and that's not even taking into consideration that it won't tailstand.
    "White C4® LED delivers 45 lumens; 420 candela; 41m beam; runs 2.25 hours", that's the official data about the Microstream. But our E13 is 120 lumens, and the running time is about 50-60 minutes depends on different AAA batteries.
    As for tailstand, some users may love that type, but some others may not.
    Mar 2002
    I'm not going to argue with you. For me, your light would serve no purpose. I wish you well with it, as others may find it acceptable.
    But I think it is OK. It can be a good gift to children. It cannot sever you a lot time, but can help you in emergence. I think "Light and Bright" are the most important in this light.
    You are right. A flashlight cannot meet all needs.
    I think you may change the flashlight to three modes and tail stand, which are preferred by more users. Do you think so?
