Olightworld
- Joined
- Dec 11, 2014
- Messages
- 579
The PL-2 Valkyrie is the brightest compact weapon light on the market using a CREE XHP35 HI Led delivering a scorching 1200 lumens. The light uses two side by side CR123A batteries in common form factor to the industry for a known and comfortable feel. The light features a TIR optic lens providing a 245-meter-long focused beam that is still wide enough to see all around you to eliminate any blind spots in the dark. The heavy duty quick attach and release mounting system allows the light to have a tight hold on any firearm with a 1913 or Glock style rail. The ambidextrous switch allows the user to continue to use their preferred grip on the firearm while still being able to activate the switch at a moment's notice in a high stress situation. The PL-2 Valkyrie is a highly powerful self-defense tool which will blind an aggressor at close proximity indoors while still offering an extremely long distance for perfect use on rifles like the AR-15.
The PL-2 is currently up for pre-order in the USA at https://www.olightstore.com/led-flashlights/safety-and-self-defense/olight-pl-ii-valkyrie and available internationally soon at select dealers.
KEY FEATURES
KEY FEATURES
- Powered by two CR123A batteries with a single output of 1,200 lumens
- High performance Cree XHP35 HI LED paired with a narrow-angled TIR optics lens with an anti-reflective coating providing a beam distance of 245 meters
- 6061-T6 aluminum alloy structure with military grade type III hard anodizing
- Silent on/off switch for self defense. Push forward directly or hit the side of the switch to activate.
- Applicable on MIL-STD-1913 and Glock sized rails, with both "1913"and "GL"adapters provided in the package.
- Three modes provided: momentary on, constant on, strobe
- Manual quick attach and release mounting system that can be used with one hand
- Custom battery compartment lock design to prevent accidental opening
- Standby current under 30uA
- IPX6 waterproof
