Test/review of Tronic AA 2300mAh (Silver-Black)
HKJ
Copenhagen, Denmark
[size=+3]Tronic AA 2300mAh (Silver-Black)[/size]
Official specifications:
  • Voltage: 1.2V
  • Capacity: 2300mAh
  • Low self discharge (LSD): 75% after 1 year
Maximum temperature raise at different discharge currents: 1A:+1,9°C, 2A:+5,2°C, 3A:+8,8°C, 5A:+16,2°C, 7A:+22,3°C, 10A:+26,5°C
A fairly cheap brand of LSD batteries.
These curves do not trace fairly well, especially not at higher current.
Note: I had a glitch on my test station when testing the A cell at 0.1A, that is the reason for the early termination.
On these curves it is a bit easier to see that the A cells is bad at higher current and it cannot even deliver 5A. The B cells performance is more average.
Here it is very obvious that the internal resistance of the two cells are very different.
[size=+3]Conclusion[/size]
The B cell in my test has about average performance, but the A cell has rather poor performance.
If the batteries are used in fairly low drain devices this will not be a problem, but the batteries are not good in high current devices (Anything that can run them dry in less than 1-2 hour).
[size=+3]Notes and links[/size]
The batteries was supplied by a reader for review.
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
apagogeas
Thanks for the detailed review HKJ. I want to add that Tronic also has a 2400mAh version of those Energy Eco which is very bad, in Maha they register 1200-1400mAh tops, all the batteries. I have been using these 2300mAh in LED lights (AA to NP-F adapters), 6 batteries altogether and they perform very well. For the price I can't complain, neither I would feel sad if I accidentally over discharge them. After 2 years in such use they have shown some decline in capacity (about 100-200mAh) but again, for the price I cannot complain; job is done and they still perform.
TinderBox (UK)
England, United Kingdom
Great review as usual , I have a few dozen of these battery and they all test at over 2200mah at 0.2C so not bad at £2.99 for a pack of 4, though they are only rated for up to 1000 cycles.
At least Tronic battery are better than there NEW chargers, I had 3x lcd Tronic battery chargers go BANG :poof: when i turned on the power with the battery`s installed, no wonder they were only £9.99 each.
I lost hope in the new lcd chargers and bought three 7 year old led model never used from eBay and they work great, and don't feel like they are going to blow of the bench.
John.
HKJ
Copenhagen, Denmark
Looks like the discharged capacity at 100ma may needs a correction??
That is a bit problematic, it looks like my discharge was terminated premature (Look at the 0.1A curve for the A cell).
As a fix I have duplicated the values from the B cell, this is not completely correct, but it is more correct.
