Imalent
Results 1 to 24 of 24
Thread: Test/review of Battery tester ZTS Mini-MBT
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/review of Battery tester ZTS Mini-MBT
    The ZTS tester is fairly advanced battery testers that uses some sort of pulse test. This is one of the smaller models. I will see how good it is, how it do its magic and how it is build.
    This model includes a small bag for it.
    The front has one connection for a couple of battery sizes.
    The other connection is hidden in a slot on the device (A neat solution).
    There is also a power button on the box, a press will turn the device on for some time, power off is always automatic.
    When a battery is connected the lights run left and right a couple of times, before a single led lights up showing the estimated remaining energy.
    Measurements
    • Power consumption when on and idle is 17.5mA
    • Power consumption when off is below 1uA
    • Power consumption when testing is 31mA
    • Power consumption when showing result is 78mA (The relay is using a lot of power).
    • Power on time is about 2 minutes
    • Works down to about 4 volt on the internal batteries.
    • The power led will flash when internal batteryes are too low.
    To test the tester I discharged a AA alkaline battery in 100mAh steps and put it on the tester for each step (I discharged with 100mA).
    Each time I checked the state on the ZTS I did multiple tests, if the tester changed between two values I recorded a value between, i.e. a indication of both 60% and 80% was recorded as 70%.
    The dots above shows the ZTS indications, the green line is the correct remaning capacity.
    This curve was done over two days, this means the battery got a lot of rest time at some of the measurement points.
    I did the same test with a NiMN, (2000mAh Eneloop discharged with 500mA).
    As expected it is very difficult to measure charge state of NiMH batteries.
    The pulse loading is one 2 second pulse at around 150mA for alkaline batteries.
    With NiMH the current is 350mA and the pulse is slightly longer.
    LiIon batteries are pulsed with 700mA
    Because there are different LiIon chemistries with different voltages, this cannot be very precise.
    And CR123 is pulsed with 750mA
    Tear down
    It was easy to open, I just had to remove a couple of screws, but removing the circuit board required desoldering the two connections to the battery box.
    The 5 level leds (D1 to D5) are smd leds and marked with the color. There is also a power led (D6).
    Q1 is used to drive the relay and Q3 is probably used together with the power switch.
    Z1 may be the reference.
    It can also be seen that the circuit board can be used for another MBT model (There are holes for some other battery terminals).
    On this side is the microprocessor (U1: PIC16F1507), the load resistors and a relay to disconnect the loads.
    Conclusion
    The device is not a precision meter, but it can give an idea about the power remaning in a battery
    Compared to many other battery testers it has the advantage of a well controlled load, both current and time.
    Notes
    I got the device from a reader.
    Here is some voltage tables for estimating remaning energy in LiIon batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Oct 2013
    USA
    Default Re: Test/review of Battery tester ZTS Mini-MBT
    [...] LiIon batteries are pulsed with 700mA Because there are different LiIon chemistries with different voltages, this cannot be very precise.
    Indeed, it will surely be way off in many cases. Why did you skip graphing this case?
    It is not clear how to interpret the graphs. What is the meaning of the Y-coordinate (voltage) of the ZTS dots? Is it the voltage under load during its test, or before the test? Does each dot represent one test or the average of many? How much rest did the cells have after your discharge before being tested on the ZTS?
    Finally, what percentage range does ZTS claim for each color? (the graphs are meaningless without knowing that)
    Flashaholic* ChibiM's Avatar
    Aug 2009
    Holland/Tokyo
    Thanks for the test. I've been interested in seeing this!
    With Alkalines its fairly accurate between 0-60%
    NiMH isnt very accurate at all. When showing 80%, it can even be 40% actual charge left. Thats a big difference.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Gauss163 View Post
    Two reasons:
    1) Time, I cannot automate this, but need to check the batteries many times over 1 or 2 days.
    2) I would need to check at least two types of LiIon to get useful charts
    The voltage is used for the red line, the ZTS dots are related to the green percent scale, like the green line.
    As I wrote each dot is based on a number of tests, the resting period is unspecified (minutes to 10 hours for the alkaline).
    I did include this image:
    Oct 2013
    USA
    So the y-coordinate of the colored dot indicates the percentage reported by the ZTS (average over some number of tests)?
    Your graphs show additional colors (e.g. red) There is not enough info to determine the ranges that ZTS claims for each color. In order to judge the accuracy of the meter the reader needs to know the claimed ranges for each color, e.g. green = 80-100%, orange = 80-60%, red = ... or something similar. Keep in mind that the reader may have neither the device or its instructions,
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Yes.
    You can just ignore the color, it is only included to make the chart look pretty and match the display on the MBT, but do not affect the percent.
    Oct 2013
    USA
    My point is that the reader needs to know further info such as the resolution of the LED meter. Can it only report values that are multiples of 20%, or do they use some scheme with colors and/or blinking LEDs to report multiples of 10%, or some similar interpolation scheme? We cannot accurately calculate the error of the device without knowing these details (normally one graphs ther error since it gives at-a-glance some intuition on the accuracy and, furthermore, eliminates the need to know the answers to said questions),
    You still have not explained the denotation of the y-coordinate of the colored dots.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    My point is that the reader needs to know further info such as the resolution of the LED meter. Can it only report values that are multiples of 20%, or do they use some scheme with colors and/or blinking LEDs to report multiples of 10%, or some similar interpolation scheme? One cannot assess the error of the device without knowing these details.
    I believe that I explained it here:
    Oct 2013
    USA
    Is that supposed to imply that the meter can only report 5 values: 20%, 40%, 60%, 80%, 100%? When you take the average of (how many?) readings, do you round to only those values? If you took 2 readings of 20% and 40% then which value do you round to (or do you take more readings?)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Is that supposed to imply that the meter can only report 4 values: 20%, 40%, 60%, 80%, 100%?
    I would say 5 values.
    I did 5 test at each stop, if the meter showed two different leds I put the dot between the 5 fixed value. I did not do any average, a 40% 40% 40% 40% 20% or a 40% 20% 20% 20% 20% would both be marked with a 30% dot.
    Oct 2013
    USA
    Agreed (modulo typo).
    Ok, now I think I understand better how to interpret the graphs. Thanks for elaborating (and, of course, for doing the review).
    Oct 2013
    USA
    Btw, it would be interesting to determine if any further accuracy can be obtained by averaging samples. Do you still have the 5 sample points, or did you discard them because you determined that they are useless for such purposes?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    I did not write down each sample, only the result for all 5 samples.
    Mostly the latest samples will be at a lower value, the reason can be because the battery is at the edge of a lower value, but it can also be because the battery has rested and recovered some voltage, a few tests will eat some of the recovered voltage.
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    I would say 5 values....
    Or perhaps 6 (including " 0 % " or no response) ... ?
    Although I don't have this "Mini" version, I have the larger MBT-1 and (IIRC) I think there can be a battery state that triggers the "scan" but shows no capacity indicator.
    Of course, with a completely empty cell, even the scan may not trigger, and thus this could also be considered another ( 7th? ) output state.
    ... is the archimedes peak
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by archimedes View Post
    You are correct, the 20% has two indications: steady red or flashing red. I assumed the flashing red was 0% (The last dot in both charts).
    Unenlightened
    Jun 2018
    Thank you for that very thorough assessment of the ZTS Mini-MBT Battery Tester. I had been considering buying one, but I'm less inclined to do so after seeing the results of your tests.
    I HAD been interested in the ZTS product because I wanted a more useful assessment of the actual status of batteries than can be obtained by using one of the inexpensive (usually $10.00 or less) battery testers that are commonly available, which I understand do nothing more than test voltage. ZTS seemed to be the only one claiming to do anything more.
    Are there just NO reliable testers for determining a battery's actual condition?
    If there are, are any reasonably priced for home use? I felt that $50 was about the outside limit of "reasonable price" for a home battery tester, so this ZTS unit seemed to be right at that outer limit. But I can't see paying that much for a tester that has as much variance as your tests showed.
    Can anyone recommend a good battery tester for home use?
    Thanks,
    Paul
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Rather more complex than most might need, but perhaps the West Mountain Radio CBA ?
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Paul,
    Welcome to CPF.
    I use my ZTS (full size and not the mini) all the time. The principle behind the ZTS is that they do discharge tests and record the voltage under load. This information is loaded into the tester and is used to compare the cell you are testing to what their data shows.
    They build their data using quality name brand new cells. Your specific cell may have different IR which will give you different results. They regulate the pulse used so you get similar results regardless of the state of charge of the batteries that are powering the ZTS tester.
    This tester is not precise. By that I mean that if you are using a cell with 2000 mAh capacity and the tester is showing 60% that does not mean that you have 1200 mAh left. However, if you test your cell and then find that you can use it in a device for something like 90 minutes then the next cell you put in will behave about the same. When you check your cell and it is testing at 60% you have about 90 minutes of life left. I guess I am indicating that it is repeatable.
    This assumes that you don't change brands or lot number of the cells you are using. When you change brands, you are back to square one.
    Unfortunately ZTS doesn't publish they reference voltage charts and don't tell exactly what cells they use to develop those references.
    In general, if I am going for the weekend I prefer to have cells at least at 60%. If I am going for a week I want 100%.
    Tom
    Behind every Great man there's always a woman rolling her eyes...
    Most batteries don't die - they are tortured to near death, then murdered...
    Oct 2013
    USA
    Quote Originally Posted by pdalton View Post
    Are there just NO reliable testers for determining a battery's actual condition? If there are, are any reasonably priced for home use?
    If you seek a battery "fuel gauge" that is reasonably accurate and general (multi-chemistry) then you won't find one at the consumer level. It is very difficult to precisely estimate capacity for chemistries like NiMH that have large voltage hysteresis and (relatively) flat discharge curves. That's why the above ZTS and similar simple devices have huge errors.
    Honorary Aussie
    Feb 2014
    USA
    Thanks for the review on this tester. I have the larger model-and itís been worth the price.
    It is better to buy a beautiful, expensive, custom flashlight than to curse the darkness.
    Oct 2013
    USA
    Quote Originally Posted by magellan View Post
    Could you please explain how a $90 tester with over 40% error (on NiMh) is "worth the price"? I am highly puzzled why anyone would pay such an exorbitant price for such a crude instrument. Are you using it only in cases where the error is less?
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Gauss123,
    My primary use of the ZTS tester is to check various primary button and coin cells. I also check a few alkaline AAA cells and some 9V batteries. My wife has a number of devices that use these cells and the tester has been very valuable in resolving problems with these devices.
    The price of these devices runs somewhere in the $25 - 50 range. Without my help my wife has been able to figure out what is going on with a device that is not functioning. Adding up a few replacements tends to offset the initial purchase price of the tester.
    I originally purchased the unit to check CR123A cells that had developed a passivization layer to the point of hampering their use. The idea was that if you happen to end up with these somewhat substandard cells you could burn off the passivization layer using the pulsing involved with testing. This was based upon a paper from Energizer discussing the trade off of slight use and storage of these cells during longer term storage. Using discharge testing to compare we found that the ZTS indications were closer if you used your light intermittently. When turning the light on and running it until the battery died the results from the tester were low compared to actual use.
    As far as NiMh cells go, I find it makes more sense to simply replace the cell with a fully charged one than to run a series of tests on it. I take the used cell and put it on the charger.
    On the other hand the ZTS does seem to be accurate at 100% with NiMh cells. This could allow you to sort fully charged cells from those that are less than full.
    Tom
    Jun 2014
    For NiMH cells, it makes far more sense to just charge them up. Unlike lithium-ion, there's no harm in keeping NiMH fully charged and ready-to-go.
    Quote Originally Posted by SilverFox View Post
    You can just measure voltage. While it's not very accurate in determining remaining capacity, it's pretty accurate for determining if it has full capacity. The only problems I find is with cheap Chinese coin cells, which can show full voltage but in reality have nothing more than a small surface charge.
    1.35v or above, fully charged. Less than 1.35, charge 'em up.
    Oct 2013
    USA
    My primary use of the ZTS tester is to check vrious primary button and coin cells. I also check a few alkaline AAA cells and some 9V batteries. My wife has a number of devices that use these cells and the tester has been very valuable in resolving problems with these devices.
    The price of these devices runs somewhere in the $25 - 50 range. Without my help my wife has been able to figure out what is going on with a device that is not functioning. Adding up a few replacements tends to offset the initial purchase price of the tester. [...]
    Why not simply test the device with a fresh coin cell and save yourself the $90 cost of the ZTS?
    For full disclosure I should add that my objection to the ZTS has not only to do with its large errors but also the fact that ZTS has essentially patented the (very old) method of estimating capacity via pulse load tests. These patent trolls vigorously attack any similar devices. That's why you can't buy anything similar in the US so they can jack up the prices outrageously.
    Such patents greatly impede innovation. If not for that you'd probably be able to buy a smarter device for less than 1/3 the price of the ZTS. The patent could easily be overturned if competently challenged but the market for such devices is not lucrative enough that anyone has done so yet (but stay tuned - some volunteers may soon contribute on that front).
    I do factor such matters of principle into my buying decisions and recommendations. In particular, I strongly recommend against buying products from companies that behave so unscrupulously.
