littlebattery
I bought some CR2 rechargeables, and matching charger (since most every other charger supports RCR123 as the minimum length) from orbtronic.com
https://www.orbtronic.com/batteries-chargers/cr2-rechargeable-lithium-batteries-CR2-charger
They are labeled 3.0v, LiFe (Li-FePO4).
However, they are 3.8v (open circuit, after sitting for several months) and the included charger charges them at ~4v.
I first noticed this issue when i went to put a storage voltage on them in the SkyRc mc3000 (used a spacer); the mc3000 throws a _Check Voltage_ error when configured to charge(or discharge) them to 3.3v LiFe storage voltage. I'm running the same program on the mc3000 i use to put a storage charge on some LiFe 3v RCR123's ... so i don't think i am doing anything wrong there. If I tell the mc3000 to storage-charge them as normal LiIon's, it doesn't complain and discharges them to 3.80v.
Are the above voltages expected for LiFe? Could someone shed some light on what's going on?
batteries & charger pic:
charger label. As you can see, it doesn't appear to be labeled to charge 3.0v batteries!
