littlebattery
Hi all - I was having some trouble having confidence some batteries i received from a well-known vendor were actually LiFePO4 as labeled. They are the less-common cr2 / 15270, labeled as LiFe, but came intentionally with a charger that is intended for normal 4.2v termination / "LiIon" batteries. My SkyRC mc3000 would throw an error when i tried to discharge/store them, as the voltage on the cell is outside it's "safe" range for LiFe.
I'm hoping an expert here can weigh in on what, if anything, is definitive from the below charge/discharge curves. Between each phase several hours passed (eg rest time)
Sequence of events are:
From the LiIon discharge (#2 above, curves in first picture below) it looks like the bulk of the discharge happened at 3.2~3.3V in the "discharge as LiIon".
Thank you!!
1) not shown, they were charged in the LiIon charger included by the reseller
2) Shown here, the mc3000 discharges the cells, as "LiIon" from ~4.15V to ~3.22V
3) shown here, the mc3000 does another discharge cycle, this time programmed as LiFe, from ~3.22V to ~3.1V
4) shown here, the mc3000 re-charges the batteries, as LiFe chemistry, to ~3.38V.
- fully charge 2 batteries with the included "LiIon" charger (no picture). They end (after rest) at ~4.15V
- put in the mc3000 (slot 1,2) and discharge as LiIon (can't discharge as LiFe directly, the charger catches the 4.15 starting/resting voltage as an error). They end (after rest) at ~3.22V
- still in the mc3000, 'continue' discharging as LiFe. They end (after rest) at ~3.10V
- re-charge in the mc3000 as LiFe. They end at 3.38V.
Thank you!!
