Imalent
Results 1 to 3 of 3
Thread: 18650 protected cells in series
    Default 18650 protected cells in series
    I have several 8s 18650 packs with a BMS installed. If I wanted to make more of these packs could I use 8 protected cells in series and not use a BMS? Each cell should stop charging when it is full, but would his cut off the charge to the others?
    Oct 2012
    Norcal
    Default Re: 18650 protected cells in series
    Quote Originally Posted by saladsack View Post
    Yes.
    For battery packs, a BMS is FAR better than using protected cells.
    Honorary Aussie
    Feb 2014
    USA
    That's good to know, thanks.
    As I'm not an RF hobbyist, I just don't use series flashlights much anymore, at least if they're lithium ion types.
    It is better to buy a beautiful, expensive, custom flashlight than to curse the darkness.
