- Joined
- Sep 6, 2010
- Messages
- 48
One-step to satisfy all your imagination for research light: the TM38 and the TM 38 Lite, rechargeable searchlight with beam distance up to 1400 meters.
http://flashlight.nitecore.com/ILLUMINATION/TM/TM38/
http://flashlight.nitecore.com/ILLUMINATION/TM/TM38LITE/
As a new member of TM series, TM38 and TM38 Lite is the biggest sized flashlight with the farthest throw up to 1400 meters. As if it is a light saber in darkness, TM38/TM38 Lite emits up to 1800 lumens. The rechargeable grand throw searchlight TM38 and TM38 Lite has the unprecedented beam distance of 1400 meters.
TM38 and TM38 Lite utilizes a CREE XHP35 HI D4 LED, integrated with the CREE breakthrough technology SC5 to greatly improved the beam distance by 80% and light condensation by up to more than 60% in beam intensity. Innovative single button two-stage switch for controlling all functions. Daily mode and search mode are selectable.
Onboard multi-function OLED display gives overview for operating status. The intelligent charging function features automatic termination upon charge completion and a power indicator beneath the power switch to indicate the remaining power level. Built-in intelligent charging circuits with safety monitoring function make charging rapidly and safely. The charging port is dustproof and waterproof, easy to cope with various scenarios.
Equipped with NBP68 HD High Performance Battery Pack, its capacity is approximately 98Wh, the equivalent of 8×18650 3400mAh batteries, can be charged independently. TM38 Lite is compatible with multiple batteries.
TM38/TM38 Lite will provide you with the unprecedented searching experience of 1400 meters throw!
