MidnightDistortions
So since buying another BC1000 unit i got those crappy La Crosse cells. The older cells are holding up pretty well in flashlights and the string LED lights i got from Amazon, but i have a question? Should i break-in the new cells and use them (i could always find a use for them) or should i just leave them in storage for now until i actually need them. I don't have a problem using them either, i'll find a use for them if it would be better as they'll probably degrade no matter what. I was curious on your thoughts on this. I may at least do an IR test on them with the C9000 to see if they are even new or they have been sitting for a lengthy period of time.
I know with Eneloops and high quality LSD cells you don't have to use them right away as they'll still function well if you let them sit in storage for a long time.
