Hi sbslider,
my line of thoughts: IF the voltage of a charged battery = 1.4V AND the low voltage cut off of your light = 0.9V THEN the voltage drop on battery due to IR must not be higher than 0.5V. 500mV @ 2Amp => max IR = 250 mOhm
- standard Eneloop - 1800 mAh, 2100 mWh, 750 cycles till 250 mOhm -
http://aacycler.com/battery/aa/panasonic-eneloop/
- IKEA LADDA - 2350 mAh, 2800 mWh, 170 cycles till 250 mOhm -
http://aacycler.com/battery/aa/ikea-ladda-2450/
- Eneloop Pro - 2400 mAh, 2850 mWh, 130 cycles till 250 mOhm -
http://aacycler.com/battery/aa/panasonic-eneloop-pro/
If you were to recharge your cells daily this is what I predict:
- cycles 0-100 (0-3 months) - Eneloop runtime 1 hour, LADDA/PRO runtime 1 hour 24 minutes. You love your LADDAs and PROs, you hate your Eneloops
- cycles 100-150 (3-6 months) - LADDA/PRO runtime dropped to Eneloop runtime. You wonder what happened to your LADDAs and PROs
- cycles 150-200 (6th month) - your LADDAs and PROs died. The standard Eneloops still perform as at day 1, still 1 hour runtime
- cycles 200-400 (6-12 months) - still 1 hour runtime
- cycles 400-550 (12-15 month) - runtime dropping to 50 minutes
- cycle 551 - your flashlight is stolen. You don't mind, because you are already considering buying a new one, with double the luminosity and half the current
Cheers,
AA Cycler
