Wuben
Results 1 to 27 of 27
Thread: Portable thrower comparison with lots of graphs
    Flashaholic* The_Driver's Avatar
    Jan 2010
    Germany
    Default Portable thrower comparison with lots of graphs
    Here I have created a google spreadsheet which compares the throw of all the portable (battery powered and handheld) throwers which I have found out about through the years. It doesn't matter if they are stock or modded or what light source they have. It also includes many different graphs for comparing them. Each light is linked in the first sheet. Generally the light should throw farther than the current best stock led thrower, the Thrunite TN-42 which does around 700kcd (excluding speciality/short-arc HIDs and incans).
    At the bottom the different tabs can be clicked on (one per graph) and there is a button to the left which opens a pop-up with a list of all the tabs.
    I will gladly add any additional lights you might know if you can provide a link to a description and a throw measurement.
    Default Re: Portable thrower comparison with lots of graphs
    Thank you for posting this comprehensive and valuable data. This is exactly what I have been looking for.
    Imalent R90TS. Acebeam two X65Vn, X45vn70.2. Eagtac MX25L4CvnT XP-L. Fx TK75vnQ70. Nc TM06Svn 4 x XHP50.2. Meteor M43vn XP-L dd. P60vn Quad XP-L HD 2 cell host Cryos Cu head. Tnt TN36UTvn, TN42vn.
    Quote Originally Posted by richbuff View Post
    I just wanted to create my own short-arc beamshots and saw this thread.
    Will read now
    I need to do some measurements to get into that list )
    Jan 2010
    Germany
    Yes, of course. The farther the distance you measure at, the better. It would be nice if you also determine the diameter of the large opening of the reflector of each light.
    Flashaholic PolarLi's Avatar
    Nov 2013
    Norway
    Thank you for posting! Appreciate all the work that went into that list
    I also see that I need to buy some batteries and a inverter for a certain beast
    Quote Originally Posted by PolarLi View Post
    Ohh, i love to see you!
    Quote Originally Posted by The_Driver View Post
    Here I have created a google spreadsheet which compares the throw of all the portable (battery powered and handheld) throwers which I have found out about through the years. It doesn't matter if they are stock or modded or what light source they have. It also includes many different graphs for comparing them. Each light is linked in the first sheet. Generally the light should throw farther than the current best stock led thrower, the Thrunite TN-42 which does around 700kcd.
    At the bottom the different tabs can be clicked on (one per graph) and there is a butto to the left which opens a pop-up with a list of all the tabs.
    Another thrower would be the Streamlight HID Litebox, 1 million candela, 2000m throw.
    http://www.streamlight.com/en/produc...tandard-system
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Quote Originally Posted by mrsteel View Post
    Not even close to the Gen3 Maxabeam at between 12,000,000 and 13,000,000 CP The litebox, iirc, is just a 35 watt HID. Not much more than a single automotive headlight and not even remotely a thrower like any Short Arc light. Maxabeam is the Throw-King of handhelds, hands-down. But you won't get a new one for $1,500. You'll need to UP your budget to probably at least $2,000, probably more.
    WWII 60" Carbon Arc (Sold), 1.6KW NightSun, 1KW VSS-3A, .8KW TrakkaBeam, 600W M-134 Light, 500W X-500-14s, 500W Starburst, 500W A120b, 450 Watt AEG German Leopard 1 Tank Light, 300W Locators, Megaray, 150W Communicator, Maxabeam Gen3, Pichel 75W Mini-Novas
    Nov 2011
    north carolina
    Quote Originally Posted by BVH View Post
    yep, thats a maglite, compared to the maxabeam
    Jan 2010
    Germany
    I have added it, thanks.
    One thing to note - it has a huge reflector (I estimate around 180mm diameter)!
    Well this is a comparison of multiple lights. It shouldn't include just the Maxabeam.
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    I like this list. Thank you!
    Flashaholic* XeRay's Avatar
    Feb 2006
    Ogden, Utah
    Quote Originally Posted by Patriot View Post
    It's been a long time Patriot, welcome back !!!
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Yeah, almost thought I was "seeing things" when I saw his post.
    Jan 2010
    Germany
    Hi Patriot, glad you like it!
    Flashaholic* Juggernaut's Avatar
    Feb 2008
    A place in need of light.
    Ok guess it's time to find me a good Lux meter.
    “What do you mean LEDs are more efficient then Incans?”, that’s just what they want you to think! It’s a Conspiracy, Man!
    Jan 2010
    Germany
    Quote Originally Posted by Juggernaut View Post
    Yes!
    Jan 2010
    Germany
    I have added the TN42vn90
    Banned
    Aug 2013
    Valley Forge, Pa.
    Thanks for the list. My TK61vn V4 is ~775Kcd/1700 Lumens.
    Justin tested the Prototype with those numbers below. The V4 has more lux than the prototype.
    Fenix Tk61vn V1.9 prototype
    Samsung 20r
    1630@ turn on
    1554@ 30 sec
    920 high
    531 mid
    189 low
    Throw - 741,000 lux
    Banned
    Aug 2013
    Valley Forge, Pa.
    I will soon get this:
    Eagletac M25C2vnT - 550Kcd Rifle Spotter
    Factory Link Click Here
    • DriverVN4 Option
    • Oslon Black LED
    • Excellent throw for the size
    • ANSI Lumen: 750
    • Intensity: 550Kcd
    • Throw: 1483m
    This can join also join the list IF multiple emitters qualify.
    And this!
    Jan 2010
    Germany
    I will add the TK61vn v4.
    You seem to mention this light in half of all your posts here...
    Concerning the other lights:
    Nope, as I mention in the first post, I only consider lights which are better than the best stock LED Thrower (TN42 - 700kcd) to be of interest. Otherwise the list would be overly long.
    Banned
    Aug 2013
    Valley Forge, Pa.
    OK,,,Thanks
    However, I did notice that you listed ~ 15 lights Before the TN42 that were from 100Kcd to 562Kcd? That is why I listed the others.
    Jan 2010
    Germany
    Well yes, I guess the list is a bit subjective in this regard.
    The maglite is there because everybody knows it. The Olight SR-90 was the first stock LED thrower to hit 100kcd. Then there are some well known and some specialty (very throwy) HID lights. Also there are some incan lights which are rather throwy (but they will always "suck" because of the physically limited luminance of incandescent bulbs).
    Banned
    Aug 2013
    Valley Forge, Pa.
    I learned something. People from GERMANY can exaggerate!
    My Girlfriends Mother was born in Kindenheim,Germany. SW of Frankfurt and 12KM due west of Manheim.
    TK61vn V4
    Taken last night TOWER IS 902 yards away.
    I tested this light at almost twice[1634m/1787yds.] that distance and it shed usable light on a cell tower.
    Thanks again for the thread! The TK61vn V4 can now rest!!!
    Jan 2010
    Germany
    I have now started adding otf lumen values (when I can't find measured values I calculate them myself based on multiple factors) and am calculating the luminance of the light source in each light based on multiple factors.
    Nov 2007
    Germany
    Have you considered adding the MAXTOCH Xsword L2K to the list?
    While featuring a somewhat unwieldy name, the claimed throw is immense.
    It would be nice to have an early representative of the potentially disruptive LEP technology on the list.
    happens
    Jan 2010
    Germany
    Quote Originally Posted by Helmut.G View Post
    I have added it.
