lawmanstumpy
- Joined
- Aug 16, 2017
- Messages
- 1
Stinger goes dim after short continuous use, then after a rest goes bright again, then repeats the dim process. If switched to the strobe function, it will cycle for half a second and then stop. Once I turn the light off and back on again its normal. Could this be a tail cap switch problem? I have already replaced the battery to no avail. I haven't taken it to a service center yet for diagnosis, trying to figure out if its an easy fix.
