HKJ
[size=+3]Efest IMR18650 2600mAh (Purple) 2017[/size]
Official specifications:
A 2600mAh high current 18650 cell.
Nice tracking discharge curves with nearly constant capacity.
At 30A continuous discharge current the cell gets too hot.
[size=+3]Conclusion[/size]
This looks like a very good high current cell and it can easily deliver the rated 25A current.
[size=+3]Notes and links[/size]
The batteries was supplied by Efest for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Rated capacity: 2600mAh
- Nominal voltage: 3.7V
- Voltage at end of discharging: 2.5V
- Max. charging current: 4A
- Standard charge: 2A
- Discharging current 25A
- Pulse discharging current: 40A
- Charging temperature range: 0°C ~ 45°C
- Discharging temperature range: -20°C ~ 75°C
- Inner resistance: 20mOhm
- Cell size: 18.50 (±0.20)mm x 65.20 (±0.2)mm
