HKJ
[SIZE=+3]Delipow 9V LiIon 800mAh (Yellow-green)[/SIZE]
Official specifications:
A cheap LiIon 9V battery from China
Overcharge protection on the A cell kicks in at 8,46 volt and over discharge protection at 5,53V
Overcharge protection on the B cell kicks in at 8,46 volt and over discharge protection at 5,56V
It do not have the rated 800mAh, but the discharge curves looks good for a 590mAh battery.
[SIZE=+3]Conclusion[/SIZE]
The capacity rating is too high, but it looks like a acceptable LiIon 9V battery.
[SIZE=+3]Notes and links[/SIZE]
How is the test done and how to read the charts
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
- Battery Type: Li-ion Battery
- Rated Capacity: 800mAh(0.2C discharge)
- Rated Voltage: 8.4V
- Discharge cut-off voltage: 7V
- Charging Voltage (standard): 9V
- Discharge current (standard): 50mA
