Looking for recommendations for what to me would be sweet spots for flashlights:
a) smallest possible flashlight, 10w for use with 18650 battery. regulated power supply (constant current), switchable to something close to 10w and 5w (50%). With zoom (narrow/wide-angle). And smallest possible means that i do not care for the tube being so thick that one could fit the silly 3*AAA adapters inside.
b) Same as a) except for use with 2 * 26650 batteries.
My reference so far has been the 4 * c-cell duracell durabeam 1000, which i believe looks very much like running the single cree LED in it at 10w and gets close to the 1000 lumen it promises. Alas, these can not run on rechargeable c-cells because they do not have a current regulator so they burn out immediately or after a short while on rechargeables.
I found one ca. $9 flashlight, 2*26650 with XML-U2 that has regulated output and nicely keeps power / brightness stable down do ca. 3.7V, alas the regulator runs the output at close to 4W so it is quite dim. No idea why they didn't put a 2A or 2.5A regulator into it to actually utilize the 10W of the cree.
The $10 flashlight for 1*18650 with XML-T6 i found does nicely go up to almost 10W at full battery, but alas its does not seem to have a real regulator at all, so it just dims down as the battery goes down.
If there are no reasonable options (aka: <= $30 is reasonable (without batteries), < $50 is something i'd suck up... maybe. Beyond that, price is IMHO unreasonable), i would also consider modding the flash lights myself with some cree+driver module. Recommendations for that welcome as well. Seems that the driver for 2*26650 would just need to be step-down, but the driver for 1*18650 ideally would have to be step-up/buck-converter if i am not mistaken.
Thanks!
Thanks!
