Results 1 to 2 of 2
Thread: Test/review of Golisi IMR26650 4300mAh (Gold)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/review of Golisi IMR26650 4300mAh (Gold)
    Official specifications:
    • Nominal capacity: 4300mAh
    • Constant discharging: 35A
    • Nominal voltage: 3.7V
    • Discharging cut-off voltage: 2.75V
    • Charging cut-off voltage: 4.20V +/-0.05V
    • Internal resistance: 30mOhm
    • Standard charging current: cc/cv <=2A
    • Operating temperature: Charging: 0°C ~ 45°C, Discharging: -20°C ~ 60°C
    This is a high current 26650 cell with moderate capacity.
    The batteries easily handles up to 20A without any significant drop in capacity. The curves tracks fairly well, with only a minor capacity difference.
    The 15A discharge curve for the A cell is missing, my equipment had a fault during the charging after the 10A test.
    The battery gets hot during a 30A discharge, but not too hot.
    A 30A discharge current is usual problematic for a 26650 cell, but not for here, the cell can handle it.
    This is definitly a high current cell!
    Notes and links
    The batteries was supplied by Golisi for review.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Compare to 18650 and other batteries
    My website with battery, charger, usb reviews, comparisons & information:
    Latest addition is multimeter reviews
    Nov 2012
    Manila, Philippines
    Default Re: Test/review of Golisi IMR26650 4300mAh (Gold)
    I emptied my battery and used my Xtar charger and it showed almost 4900mah in it when it was done it took around 12 hours to charge it. So from now on I use my flashlight to charge it. Big difference using 2 amp instead of .5 amp. Overall I am very happy with the quality of the battery.
