1x10180 130Lumens
Mini Titanium Rechargeable Keychain Light
******Klarus Mini One Ti ******
---Release---
---Release---
The Klarus Mini One Ti is a very durable and reliable professional grade 130lumens mini titanium rechargeable keychain flashlight. It offers a user friendly interface, easy to use, fast charging for only 45minutes with a hidden Micro-USB port and a 10180 battery included, and you can switch between levels and power the light on or off by simply twisting the head switch.
Weight: 16g/0.56oz(with battery)
Dimensions: 1.73inches for length and 0.53inch for width
Lowest Setting: 8lumens for 5.2hours
Highest Setting:130lumens for 24minutes
Klarus Mini One Ti YouTube Review by Gear Nut
Equipped with CREE XP-G3 LED and high efficiency drive circuit, the mini keychain flashlight Mini One Ti is extremely compact and super bright, it uses one 10180 Li-ion battery to deliver 130lumens with beam distance up to 30meters.
The rechargeable keychain light Mini One Ti comes in at just 1.73inch(44mm) for length, 0.59inch(14.9mm) for head width and only 0.53inch(13.5mm) for the light body diameter, lightweight at only 16g include battery, all makes it one of the smallest lights or one of the smallest keychain lights.
The keychain light Mini One Ti is exquisitely compact, it is designed with bullet shape and slip-proof grooves based on Titanium Materials, makes it lightweight, rugged, anti-corrosion, as well as extreme heat dissipation.
The keychain light Mini One Ti is a 1x10180(battery included) rechargeable keychain light with hidden Micro-USB charging port, only need twist the head to show it out, and this design makes the mini keychain light not only waterproof and dustproof, but also fast charging that only need 45minutes.
With professionally designed TIR Optic Lens with diffused surface, the keychain light Mini One Ti generates soft light with even spot without glare.
Tail stand design for hands free, rotary switch to change the modes easily, simple and quick operation for daily tasks.
Though ultra-compact, the keychain light Mini One Ti is IP68 waterproof and dustproof, it supports to be underwater 2 meters, impact resistance to 1.5meters.
The keychain light Mini One Ti work with 2 lighting levels, high mode at 130lumens last for 24mins, while low mode at 8lumens last for 5.2hours, the peak beam intensity is 217cd.
