Hi all,
i am looking at the SC600 mkIII HI and had some concerns with the batteries. I have never used 18650s I have only used CR123s. Since the mkIII only takes unprotected cells can you recommend some that are good. I also have concerns about discharging the cells too much. I often use my torches while camping and (after a few beverages) I lose track and drain the battery until the light is dim or no longer working. In my javalot m2X a strobe kicks in when the batteries are low. Is this dangerous with 18650s? Do I need to worry if I use unprotected cells in the MKIII? I would be cautious not to over charge them but my concern is discharging them too much. I read the guide on care of 18650s, but I'm curious if some or all torches have a built in safety to protect from over discharging. I guess my last question would be what are the dangers of over discharging as described above?
Thanks for the help!!
