SpacoOmbroj
- Joined
- Oct 26, 2017
- Messages
- 3
Hi all.
I'm looking for a battery recommendation. I have a somewhat different set of requirements, so am looking for advice on battery type, and the associated protective, balancing, and charging circuitry.
I have a torch. It is for emergencies only. It is plugged in practically 100% of the time. The light itself may automatically turn on at certain times during this (fairly often in fact) - but the torch will be connected to mains power during these times. The bulb itself is a 12V LED car headlight job. Draws about 400mA, so that's 6W max continuous. I don't NEED 12V - I will have a boost converter in place.
Voltage: 5V+.
Power: 6W
Duration: An hour? Perhaps 2? It's only for power outages.
Battery lifetime: LONG. Batteries should also be happy to sit fully charged for long periods of time.
Battery safety: Would like a safe system. This does seem to imply not lithium-something, but I know that lithium-something could be used safely in this application.
Cheerio
Sal
Voltage: 5V+.
Power: 6W
Cheerio
Sal
