Chris, thank you very much. The number of choices is quite overwhelming. Friends also mentioned the Nitecore Intellicharger i4 and powerex MH-C9000 and Panasonic BQ-CC65. I should say that looking for 2 models:
a) a home-use model that will charge at least 4 batteries at the same time (and it would be nice if it came with or could be used with a car charge adapter)
b) a lighter weight travel compact model that could charge preferably 4 batteries but at least 2. Just not be heavy and chunky like some home chargers where weight and size are not an issue.
Questions:
1) Which would you recommend for each? It seems like you can spend anywhere from $25-60 on smart home chargers that can charge 4 batteries at the same time so if I can get most of the capability from a $25-35 model I'd prefer that, unless there's a big benefit to a more expensive model.
2) A member of these forums messaged me several years ago that "the Maha 9000 and La crosse 900 are well rate but they have flaws you should read about." Is that still true?
I have the Maha C9000 w/car adapter, I have the Opus BT 3400 with car adapter, I have the Xtar VC4 which can work with a USB 12v cigarette adapter and I have a couple of smaller 1-2 slot Liitokala USB chargers.
Get the Opus BT 3100, or 3400 if you live in the USA. Get the 3A car adapter, which comes with it I think and use that for $30-$40, depending on where you buy from. The 3400 v. 2.2 is what I have and the new model version is the 3.1, it differs from the 3100 in that you can toggle off the display and you have an 'upgraded' fan. The v. 2.1/2.2 of either, has a 2.80v li-ion discharge cutoff and the v. 3.1 has a cutoff point of 3.10v.
It's a good bang for your buck charger.
All chargers have nits and flaws.
My Maha C9000 has been running strong for almost 6 years, but like any mass produced electronic item, you have some lemons out there. I also have a LaCrosse BC-700, which heats up and suspends charging at times. It's a decent charger, but at the same price as the Maha, at the time, I wish I would have gotten a second C9000, but others have no problems with their LaCrosse chargers.
They only do NiMH batteries, so that may be a negative point for you.
Chris
