The GH24 from reflectalite.com is very impressive.
It's rated at 6V/1.7A (10W) but overdriven by 3x123 it's probably pushing 14W+ and it is
bright! /ubbthreads/images/graemlins/cool.gif
I've been running one for a while now and have gone through 6 or 7
sets of batteries on the
same lamp. I've even shaken, bumped and dropped the light while on and have not blown a GH24 yet.
Doesn't focus as tight as the KRP112 so throw may be a bit less, but it puts out a
ton more light. Think of it as a "narrow flood" beam that still has loads of throw. Everyone who's seen my 2C/3x123/GH24 has been
wowed by it.
It's possible the stock Mag reflector could be damaged on an extended run. I've heard it's safe to around 12W, so this lamp is pushing it a bit. I have run mine for several minutes at a time and haven't melted anything.
Run time at these current levels leaves a lot to be desired. I haven't actually timed mine, but I'd guestimate 30 minutes. 15 of bright, white light (the whitest incan you've ever seen); another 5-10 or so of very bright, but gradually yellowing light (still brighter than my PM6 or LX); then a rapid decline to darksville.
If you want a wide area flood beam, order the GH24F (frosted) version. Works really well with the Mag reflector. Bright hot spot with a gradual fall off to a wide and very smooth spill. Sort of a flood with a central peak. I run the GH24 in the light, but have a GH24F in the tail cap in case I need more of a flood beam. Just a quick switch and I'm good to go.
Went night diving Saturday at a beach that has a long downhill hike to get there, so I brought this along to light the way. From the top of the cliff the Mag out threw my UKE Light Canon HID light. I could look down into the water several hundred feet away and light up the reef. The HID light was whiter in color (of course) and put out more total light, but the modded Mag was still impressive in comparison.
'course, it's not waterproof, so once it was time to get wet the Mag went into the gear bag and the LC100 HID turned night into day below the waves. The Light Canon is mildly impressive out of water, but underwater it really rocks.
But that's a subject for another thread... so anyway, try the GH24 from
Reflectalite on your 3x123 modded 2C. I think you'll be impressed. It's a very bright and fun combination. Just be sure to buy
lots of batteries.
Aloha, iG
