HKJ
[size=+3]Vapcell INR21700 3100mAh (Purple)[/size]
Official specifications:
One of the new slightly larger batteries, this one with fairly low capacity, but very high current capability.
Good tracking, expect a small capacity difference. The batteries has nearly constant capacity op to 30A and the 35A rating looks very realistic.
The cells do not get too warm at 30A discharge current.
[size=+3]Conclusion[/size]
This is a good high current battery.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Model: NCR21700
- Size: 21.0*70.2mm
- Nominal voltage: 3.6V
- End-of-charge voltage: 4.20V
- End-of-discharge Voltage: 2.50V
- Typical Capacity: 3100mAh (0.2C discharge)
- Min capacity: 3000mAh (0.2C discharge)
- Weight: Max:68g
- Internal resistance: Max:8mOhm
- Standard Charge: 2000mA,CCCV 100mA cut-off
- Charging Time: 3hours(standard charge)
- Quick Charge Current: 4000mA
- Max Continuous Discharge Current: 35000mA
- Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
- Storage: Temperature -5°C~35°C, Humidity <75%RH
- Standard environmental condition: Temperature: 23±5°C
- Humidity: 45-75%RH
