EAGTAC
Results 1 to 8 of 8
Thread: Olight R18 Pro
    *Flashaholic* kj2's Avatar
    The Netherlands
    Default Olight R18 Pro
    Was looking at my local Olight dealer, where I saw this new light. No info (yet) on the Olight website, so am wondering does anyone know more?
    Given specs are: Turbo (2100lm), High (1000lm), Med (320lm) and Low (80lm).
    Micro-USB rechargeable, comes with 18650. IPX7. Cree XHP50.
    Default Re: Olight R18 Pro
    Where did you get the photos?
    Feb 2005
    Southeastern, NC
    The tailcap looks very similar to the M2R design with the addition of an a lanyard ring. I'm assuming USB charging based on the port cover and the clip looks reversible as well.
    If its real I hope it is micro usb charging capable. While the Olight magnetic system works fine I just don't like to have to have but so many charging cables around.
    Flashaholic* maukka's Avatar
    Dec 2015
    Finland
    Olight sometimes releases light exclusively at some countries/retailers, but they usually come available worldwide afterwards.
    Found this video on YouTube
    https://youtu.be/XotdOgOCtSw
    rookiedaddy's Avatar
    Apr 2009
    A Place Called HOME
    There are 2 versions available, R18 and R18 Pro.
    For R18 Pro spec:
    • Cree XHP50 CW LED
    • 2,100 lumens
    • 230 meter distance
    • 3000mAH 18650 battery included
    • Micro-USB recharging port
    • IPX7
    Modes:
    • 2,100 -> 600 (0.5 + 140 minutes)
    • 1,000 -> 600 (1.5 + 140 minutes)
    • 320 (4 hours)
    • 80 (18 hours)
    R18 uses Cree XP-L Hi and smaller head.
    changing sigline ...
    Nov 2001
    los angeles
    With hi-tech MCUs these days, it would be easy to add a civilian mode with a lower low in their firmware. Other brands do it no problem. 80 lumens low (too high for many here on CPF) is going to cost them some customers.
    life's big questions/answers here:
    http://www.answersingenesis.org/home/area/qa.asp
    "So then, each of us will give an account of himself to God." Romans 14:12
    Unenlightened
    Mar 2017
    Europe, Hungary, Budapest
    Quote Originally Posted by Nichia! View Post
    See specs at 6:44. Another step back light :-(
    First mode that won't step back is 320 lumens. Why they tend to not implement a mode that would not step back in a couple of minutes? In this case 600 lm seems to be that potential mode.
    My daily outdoor activity (commuting with unicycle) lasts 30 mins to 1 hr. A light that outputs evenly for that long does not seem to be a mission impossible. I wonder why Olight builds lights with step-back modes instead of sustainable ones. Understand need for peeks but why that 600 (where 1000 lumen steps back to in 3 mins only) is not programmed as an option to choose. Why only 320 gives flat flux after being chosen?
