HKJ
[size=+3]Sony US18650VT3 1500mAh (Green)[/size]
Official specifications (This is for VTC3):
A older 18650 battery for tools.
There are two curves for all discharge currents, this must be a perfect match between the two batteries. The batteries has nearly constant discharge capacity up to 20A.
[size=+3]Conclusion[/size]
The battery has fairly low capacity by todays standard, but it can deliver a lot of current.
[size=+3]Notes and links[/size]
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Nominal capacity: 1600mAh
- Rated capacity: 1500mAh
- Capacity at 1.5A discharge: 1425mAh
- Nominal voltage: 3.7V
- Charge current: 1.5A
- Discharge cut-off: 2.5V
