RMSK, Inc.
Results 1 to 4 of 4
Thread: Minimum Mounting Height for DRL?
    Nov 2013
    Idaho, USA
    Default Minimum Mounting Height for DRL?
    What is the minimum legal mounting height (in the USA) for an (aftermarket LED) DRL lamp?
    Looking through Standard No.108 all I found was a specification for maximum height: 1.067 meter.
    S7.10 Daytime running lamps (DRLs).
    S7.10.1 Number. See Table I-a.
    S7.10.2 Color of light. See Table I-a.
    S7.10.3 Mounting location. See Table I-a.
    S7.10.4 Mounting height. See Table I-a. and S7.10.13(b)............
    Not more than 1.067 meters above the road surface if not a pair of lamps required by this standard or if not optically combined with a pair of lamps required by this standard
    See S7.10.13(b) for additional height limitation.............
    S7.10.13 Photometry. Each DRL must have a luminous intensity not less than 500 cd at test point H-V, nor more than 3,000 cd at any location in the beam when tested according to the procedure of S14.2.4 as specified by this section, unless it is:
    (b) An upper beam headlamp intended to operate as a DRL, whose luminous intensity at test point H-V is not more than 7,000 cd, and whose mounting height is not higher than 864 mm.
    reference: https://www.law.cornell.edu/cfr/text/49/571.108
    Default Re: Minimum Mounting Height for DRL?
    The SAE mounting height range is 15 to 42 inches above the ground.
    Nov 2013
    Idaho, USA
    Thanks Virgil. That rules out replacing my fog lamps (12" off the ground) with round DRLs
    I am now looking at low profile DRLs, such as this Hella kit:
    https://www.tirerack.com/lighting/de...44&brand=Hella
    Are there better lamps from Osram, or Philips, or other, that I should be looking at?
    Quote Originally Posted by SubLGT View Post
    Not really, no. SAE technical standards do not carry any force of law. They're recommended practices. The ECE (rest of the world) specification is at least 250mm off the ground, and as there is no US regulation on the subject, plenty of cars in the US have DRLs mounted lower than the SAE recommendation.
    If you get those, be sure to match up the angle they'll be installed at with the angle specified in the kit. That's the 15-degree kit; there's also a 30-degree kit and some zero-degree (straight ahead) kits.
    The Hella units you pointed at are quite good. You could also skip adding new lamps altogether and do this instead.
