..............What kind of amp load can I expect out of my recently purchased four sevens mini2 and mini2 turbo? They claim on their website, only their branded rechargeable can be used safely. Is this all "CYA" here-say? Can someone point me in the right direction?
Also does not help, their batteries are harder and harder to find since they sold out earlier this year. Tired of buying 123a's when I have a nite core i4 (older version) sitting next to my piles of other batteries.
An interesting predicament. At first I was going to say to just use any ole 16340 you could get your hands on. But after reading their warning on the type of battery, then I guess there is some caution that needs to be adhered to.
They need this special battery (probably some type of IMR type) to get the current high enough to meet their 1020 lumen turbo level. You probably could use a regular 16340 if you promised not to use the turbo level. Most 16340 lights have a max lumen level in the 400 to 500 level. My bet is that the current discharge level necessary to hit 1000 lumens exceeds the safe current discharge ability of a normal 16340 battery.
Google "IMR 16340 high drain". Looks like you might have a couple of choices.
............ So I've read elsewhere that 16340's are very sensitive to over discharge. Especially below 2.5v. Below is data posted from four sevens claim 2.0-4.2... Does that mean the light will discharge below a safe level if left on accidentally, etc?...............
2.50v is the cutoff where you don't want to go below for fear of ruining your lithium ion battery. With a 18650 / 2xCR123A light, they use a buck only driver and it becomes quite obvious on most flashlights that the battery needs charging when you get to 3.25v and below. That's because the forward voltage drop of an LED is around that level and a driver circuit that is not built to switch from buck to boost so as to maintain a constant current into the LED.........will just dimm.
But with a 1xCR123A / 16340 light, a good driver would want to extract energy from the CR123A cell that drops in voltage below the Vf of the LED. Thus to see them spec a voltage with a 2.0 to 4.20v threshold, it very well could have a buck/boost driver in there. Putting a power supply on the head and ramping the voltage up and down within that range will tell if it does. But my guess is that you will have to be extra careful with this light if running unprotected 16340 battery.
