I use my middle of the month check to do some exploration into how bad the super cheap china batteries are on ebay. I sifted through reviews and tried to find the highest claimed capacity rating.
I settled on a red GTL 5kMah Li-Ion cell. 24x cost me $18
Immediately upon holding one of the cells, it was apparent there was a LOT of material missing. They weighed 27.3 grams, while a good samsung cell weighs 47 grams. After cutting the cell open, it was a little over half full of actual battery roll??? if thats the correct wording. Not packed nearly as tight and CLEARLY missing the over/under charge protection it was ranting about on the side.
I think the best part about these batteries is the broken english on the side XD (I typed exactly what was on the cell)
"low reoccurring operation cist"
"Sheif-lief around 10 Years:"
"Discharge rate, no "memory effect""
"DO NOT puncture, damage, and disassembie."
When I put these in my zebralight headlamp on the max power (1100cp) it runs for about 2 minutes until the voltage sags below the dimming low battery function. Im currently discharging it to a safe voltage and will recharge and report back with the numbers.
I was going to post pictures, except tinypic is down atm.
-HV
-HV
