LichtAn!
Hey,
I got a little technical question. If a PWM driver on 100% is direct drive, 50% LED brightness would be achieved by pulsating the voltage to achieve the correct amount of average voltage. What happens if my batteries are so depleted that my direct drive mode is basically as bright as the 50% was with full batteries? Will the 50% mode then be the same as DD or will it be 50% lower than the 50% mode was initially with full batteries?
I'm asking specifically about Vinh's drivers (DriverVN) to understand how they react to depleting batteries.
