Wuben
Page 1 of 2 12 LastLast
Results 1 to 30 of 35
Thread: Obtain High Drain 18650 Cells
    Flashaholic* MrAl's Avatar
    Sep 2001
    New Jersey
    Default Obtain High Drain 18650 Cells
    Hello there,
    I've been asking around, where is a good place to get high drain 18650 cells.
    What i need them for is a high power 7 LED T6 CREE flashlight. As you probably know, each LED can take somewhere around 10 watts. That means that the max power should be thought of as around 70 watts. 70 watts divided by 4 volts is a bit less than 20 amps. I like to use two cells to run this, so i'd like each cell to be able to handle 20 amps min. So that means each cells has to have a rating of "max discharge current" of 20 amps.
    Second problem is i need buttons tops, not flat tops. I have flat tops and modified them, but i dont like that, i want button tops this time.
    So that is two main features i need: Button top + 20 amp discharge ability.
    Any help finding a good place that cells these for a reasonable price? Cant seem to find any yet.
    Also, i may make a move to a 12 LED light, which would be 120 watts max so the 20 amp discharge rate would be good to stick too.
    Thanks a bunch for any ideas of links. Also, any better ways to mod flat cells into button top cells would be nice too.
    Take care,
    Al
    LED's vs Bulbs, the battle is on.
    My bumper sticker: "I Brake for LED's"
    To err is human, to theorize divine.
    Got Light?
    Nov 2007
    Gulf Coast
    Default Re: Obtain High Drain 18650 Cells
    Some reputable shops are illumn.com, IMR batteries.com mountain electronics and RTD vape.com. You probably need a Sony Vtc cell rated at 20 amps continuous. Adding a drop of solder to the positive end (solder blob) will allow use where button top cells are required if button top cells are not available.
    Good luck!!
    Mar 2017
    Long Island NY
    Orbtronic model ORB-3000-20A is available in button top, rated at 20A.
    Mountain electronics sells the LG IGR18650 HG2 in button top rated at 20A. They have an Efest button top rated even higher.
    Frank
    *Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    I ordered an Emisar D4 219C quad 'Trident sub launched nuke' in December and it pulls 15A-20A on canned sunshine mode, so I went with a Sony VTC-5A cell and its 30A+ continuous rating to give me a bit of cushion. Capacity is only 2500mAh, but who cares? It's canned sunshine in a small package.
    Lithium-Ion wholesale out of Pennsylvania is where I got them from, but the above listed dealers are all kosher and I've used them myself.
    You may need button tops for your particular light, but I did not, so those might be a bit harder to source.
    Good luck.
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
    Sep 2001
    New Jersey
    Hi,
    Thanks again for the replies. I'll have to check out some of these cells mentioned and see what i can find.
    Just to note though, i am against soldering any cells of any kind. I am also against using solder for any end of any battery that has to rub on the contact during installation as mine do. When you insert the batteries, you have to twist the body, and that eventually causes the tops of the batteries to rub on the contact. Yes, i used dielectric grease but if the solder rubs it will start to rub off on the contact area and i dont really want that to happen.
    I was able to make up some little 'triangles' to mod my flat cells, but that's a real pain and i dont want ot have to do that again.
    Yeah Chris, i was amazed at what these kinds of lights can do. Mine lights up the whole back yard and it's only 7 T6 type so i could imagine what 12 or more would do. You did not mention what kind of LED's or how many your light has so i'll try to look it up.
    Take care,
    Al
    Got Light?
    Feb 2012
    Miami, Florida
    Quote Originally Posted by MrAl View Post
    Hi,
    Many 3rd party vendors like those mentioned will either add button tops to bare cells, or they'll add a protection (protected cell) circuit (PCB) and a button top and charge for that service. You just have to peruse the various sites and see what's what and what's in stock and buy accordingly. There are other great cells, like the famed Samsung 30Q, the 35E (or something) that might suffice, as well as the Sanyo-Panasonic NCR18650GA for a 10A continuous load and those by LG, so look around.
    The Emisar D4 is made by Hank of Noctigon fame and there's the D1 (bigger head, single LED) and the D1s which has a 2" head and single LED, for better throw than my 'wall of light' D4.
    The D4 is a quad emitter, smaller headed light that can be had in various emitters--in my case the Nichia 219CT LEDs, but you can get the Cree XP-L HI LEDs at a surcharge of $18.
    Google International-Outdoors, Noctigon, or Emisar and you'll see Hank's offerings. He's the Hank of the M-43 Meteor, 12 LED fame.
    $47.40 shipped in cyan, with the 219CTs, a cyan 18350 body and a pretty decent pocket clip. 20 days from 'submit.'
    Every 'well lit' man should have one, much like a 1911 45acp.
    Chris
    Sep 2001
    New Jersey
    Hello again,
    Thanks for the new reply Chris.
    What i may have forgotten to mention is that i was hoping to stay under 20 dollars (20 or less) for two cells.
    I am not sure that a 10 amp rating will be enough, because there are seven LED's that can draw 3 amps each and i like to use just 2 cells instead of the full 4 the body takes. If i use 4 cells then i have to purchase and maintain 4 cells instead of just 2. Four cells isnt out of the question i guess though, which would bring the 10 amp ones into range.
    So 3 times 7 is about 21 amps total, and i like to have some elbow room there, so two 20 ampere's would do it.
    Right now i am using two 30 amp rated cells, but as i said they were flat tops modified.
    Cant use the magnet trick either because the dang top rotates relative to the battery tops so it would cause them to shift.
    Take care,
    Al
    Got Light?
    Feb 2012
    Miami, Florida
    Hello again,
    I would buy 4 button top cells and just pay the piper. Keep them married to the light and if it $28, or $32, that's what it is. I'd rather pony up the extra cash and run four of them and leave a little wiggle room, which is what I did for my Mountain Electronics Supfire M6 Option 2, which runs them in parallel, but needs button tops--Samsung 25Rs, for 20A continuous.
    Chris
    Sep 2001
    New Jersey
    Hello,
    Yes that sounds like good advice.
    I also see that the high drain cells (Mountain Electronics and others) seem to be all unprotected.
    I have to wonder if any are button top, high drain, and protected too.
    Take care,
    Al
    Got Light?
    Feb 2018
    NW PA.
    Hello,
    Here you go. a little pricey considering you can get the bare cell for about half the price. It has a SONY VTC6 cell under the wrap.
    https://www.illumn.com/batteries-cha...utton-top.html
    Sep 2001
    New Jersey
    Quote Originally Posted by ChrisGarrett View Post
    Chris
    Hi again Chris,
    You think a place like Mountain Electronics would add tabs?
    Any idea what their shipping costs are (USA only)?
    Take care,
    Al
    Got Light?
    Sep 2001
    New Jersey
    Quote Originally Posted by IlluminationDomination View Post
    Hi,
    I might be able to put up with that. 15 amp max discharge, 24 dollars USD for 2 cells. A little higher than i wanted to go but then again they look like pretty good cells.
    Any idea what their shipping cost is for 2 cells? (USA only)
    Take care,
    Al
    Got Light?
    Feb 2018
    NW PA.
    Hi,
    Yes,I pretended I was buying them and the TOTAL comes out to:$27.98.
    $4 for shipping and $23.98 for the 2 cells.
    Sep 2001
    New Jersey
    Hi,
    Ok thanks, 4 dollars USD doesnt sound too bad really.
    Do you happen to have any info on the site Mountain Electronics, if they put buttons on the top of flat top cells?
    That would be a good option too i think.
    Take care,
    Al
    Got Light?
    Feb 2012
    Miami, Florida
    Hi,
    Here's the LG HG2 cell with button tops from Mountain. They're good for 15A+ continuous and they're only $7.19 a piece, if you buy four of them. Then add $4-$5 for shipping. For ~$32, you can have your cake and eat it.
    http://www.mtnelectronics.com/index....product_id=540
    http://lygte-info.dk/review/batterie...own)%20UK.html
    Chris
    Sep 2001
    New Jersey
    Chris
    Hi again,
    Hey thanks, i must have missed those. They look like they could do the job, and i see ratings on the web of 20 amps, but maybe that is for the flat tops.
    Take care,
    Al
    Got Light?
    Feb 2012
    Miami, Florida
    Hi again,
    Look at the second link I posted. HKJ did test them at 20A and even 30A.
    They'll be fine for your light.
    Chris
    Feb 2018
    NW PA.
    Out of the Sony VTC6, LG HG2, These 30Q BT are the best bet. They will be in stock in a week or so if u can wait.
    $5.09 a piece
    https://liionwholesale.com/collectio...teries/Samsung
    Feb 2018
    NW PA.
    Now you have choices B/W BT Protected which was what you asked for when I got on the thread and BT Unprotected which many believe are actually safer because they do Not need protection because of a different and safer chemistry.
    Good luck what ever you choose. it all depends on the money you want to spend and the confidence you have in Unprotected.
    I have very few Protected cells left, they are primarily Unprotected Sony and Samsung.
    Feb 2018
    NW PA.
    Last thought. Check out the COMPARATOR[HKJ] Info that Chris gave you.
    You will see that the 30Q beats the LGHG2 all the way through the various amp choices. 30Q has Less voltage sag from beginning, 0.2A to 20A.
    Sep 2001
    New Jersey
    Hello,
    Sounds good, but that one site it looks like they discontinued the 30Q cell.
    Take care,
    Al
    Got Light?
    Feb 2012
    Miami, Florida
    Hello,
    This shouldn't be such a difficult decision. Pick a good cell, as have already been suggested, roll some pennies and buy a quad, then number them so you can keep track of things.
    You'll probably be using the light infrequently on turbo mode, so don't worry about it too much.
    I'd venture a guess that most monster lights on this board, sit unused for much of their lives. I know I've rarely taken mine outdoors, but I carry a flashlight everyday.
    Chris
    Sep 2001
    New Jersey
    Chris
    Hello,
    You're right Chris, it's just that we kind of got to talking about it and people started to come up with some other products and i wasnt in a big hurry, plus i was hoping to get a lot in one cell like 30 Amps, button top, and protected, a combination that seems hard to find.
    I've looked around too and noticed that the flat top cells are more common and that kind of bugs me because i wanted button tops.
    Yes you are right again, i dont have to use the light that often either. Just when i go out at night. The garbage is in the back and it's very very dark back there and we get animals of all kinds back there so i like to see what i am walking into before i get there.
    Right now i am using 30 ampere Sony's with flat top modified to have a little bit of a button top. That was a pain to do though as i had to watch out i did not short the cell because these are unprotected.
    Not in a big hurry so some discussion is ok with me, but at some point i will buy and that wont be too long from now.
    Thanks for all your ideas too.
    Take care,
    Al
    Got Light?
    Feb 2018
    NW PA.
    Hello,
    What site are you talking about? The link I gave you? Liionwholesale .com.
    The BT'S are not discontinued. They are OUT OF STOCK and will be back in stock soon. I mentioned that in post #18.
    Feb 2012
    Miami, Florida
    Hello,
    Not trying to sway you one way, or the other, but you're never going to get a protected cell of 'anything' that will do 30A. The best you can hope for in a protected cell, is 10A. The circuit breaker will trip at 10A and usually 8A if you're using a cell with an 8A breaker, which was more common.
    Chris
    Sep 2001
    New Jersey
    Hi,
    Yes you are right of course, i must have clicked on the one right next to it which is discontinued. Sorry about that.
    Take care,
    Al
    Got Light?
    Sep 2001
    New Jersey
    Chris
    Hi,
    Oh that's too bad. I guess then i'll just have to settle for unprotected.
    I am always very careful with my cells anyway, in storage or in use or in charging.
    Take care,
    Al
    Got Light?
    Sep 2001
    New Jersey
    Hello again,
    I also found that if i take the very back part of the light off, i might be able to use flat cells with an aasier to modify top part.
    The only catch is that i have to take out two screws every time i change the batteries. The two screws release the board with the springs and then i can insert cells from the very back of the light, then replace the board and then the back screws on again. In this way the 'button' tops do not have to rub on anything while installing new cells so there is a more wiggle room for playing with different flat top modification techniques.
    I would not mind having small springs on top.
    Take care,
    Al
    Got Light?
    Feb 2018
    NW PA.
    $5.09 a piece
    The 30Q BT are back in stock for $5.09. FT are $4.98
    Sep 2001
    New Jersey
    Hello again,
    Thanks, i'll take another look now.
    Interesting, it says "promotional product with limited quantities available".
    Also interesting and i quote:
    Important: Do NOT remove the clear wrap on the battery. This helps secure the button top and provides an additional level of protection to the entire battery.
    I wonder how this second layer of plastic 'secures' the button top when they are supposed to be welded on.
    Take care,
    Al
    Got Light?
