Acebeam
Results 1 to 4 of 4
Thread: Fenix TK75 2015 vs 2018
    Default Fenix TK75 2015 vs 2018
    I've had a TK75 2015 for about 2 years. I'm very happy with it. I wanted to get something new, and bought the TK72. I returned it because the handle would get too hot to hold comfortably. My TK75 doesn't do that. I can leave it on level 4 for 15 minutes, and it seems to maintain the same brightness, and only the heat sink area gets hot. The handle stays comfortable to touch.
    Now I want to order the TK75 2018 edition. I've seen the curves on the box that show the highest mode turns off in just a couple minutes and drops to 2,000 lumens. I've read reviews that the 2015 edition would drop in 5% increments to keep the temperature below 65C, and my casual observations seem to say that's correct. I can't see a visible decrease in the brightness when running continuously at highest mode inside at about 70F.
    So do I have this right? The 2018 edition will time out in 2 minutes and drop from 5100 to 2000 and stay there, vs. my 2015 edition which seems to hold the 4000 lumens with no visible reduction for 15 minutes or longer. I feel like the max brightness mode doesn't mean much if it's gone after 2 minutes.
    Default Re: Fenix TK75 2015 vs 2018
    I don't have the answer to your question but you may be able to find it in this thread linked below. If it's not there you can always ask a question on that thread and many times the Fenix representative will answer it.
    https://www.candlepowerforums.com/vb...ND-5100-LUMENS!!
    "There ain't no bones in a hotdog" F. York.
    Thanks. I did read that thread and some others, and the conclusion I reached is the 2018 drops to 2100 lumens after 2 or 3 minutes and stays there, but it seemed to be debated. I'm hoping someone who has the 2018 can confirm, because my 2015 doesn't seem to act that way.
    Flashaholic colight's Avatar
    Dec 2013
    On Earth
    @mycandle, I agree with you about this, but afaik you can reselect Turbo mode when it drops down, and it will run for another period on Turbo, whatever that period is. I know this is sometimes inconvenient, but it is a new kind of overheat protection that Fenix uses nowadays.
