HKJ
[size=+3]Shockli 26650 4300mAh (Green) 2018[/size]
Official specifications:
This is a high current 26650 cell
The two cells are nearly a perfect match and capacity is constant up to 20A discharge. At 30A the cell has trouble keeping up the voltage (It need to heat up first) and the capacity goes a bit down.
The batteries get very warm at 30A.
[size=+3]Conclusion[/size]
These batteries are good at high current, but are not the best in capacity. This make them good for high current application where the most capacity is not that important.
[size=+3]Notes and links[/size]
The battery was supplied by shockli.com for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Type of Battery: Shockli 26650 4300mah IMR battery 40A
- Size(mm): 26.2±0.2mm(Diameter) x 65.2±0.2 mm(Length)
- Weight(g): 98±2g
- Nominal Voltage: 3.7V
- Nominal Capacity: 4300mah (0.2C Discharge)
- Discharge Cut-off voltage: 3.0 V
- Standard Charge: 0.3 A~3A (Recommend 0.5 A~1.5A) /4.2V±0.05V
- Maximum charge current: 3A
- Continuous Discharge Current: 30A
- MAX Discharge Current: 40A
- Initial Impedance: <14 mOhm
- Cycle Life: 300 times to 70% capacity
- Charging Time: Standard charge: 4.5hours at charge current: 1.0A
- Operating environment: Charging: 0°C ~ 45°C, Discharging: -10°C~60°C
