Timothybil
I have one of those cheap under cabinet/magnetic/velcro mount LED lights. You know the kind, two sets of COB LEDs, high/low/off, 3 AAA cells. I am sure it is direct drive because I can see the light get dimmer as the cells run down. What I am having problems understanding is how the high/low works in a direct drive setup. I know there is a 7135 component that will pass a certain amount of current, so is this a setup where there is always one of those in the circuit, and the high position adds a second 7135, or does it work some other way?
