The Fenix-Store
Results 1 to 2 of 2
Thread: [The Lite Review]: Olight I1R EOS Review
    Flashaholic mcorp's Avatar
    Dec 2013
    Singapore
    Wink2 [The Lite Review]: Olight I1R EOS Review
    Preface
    The Olight I1R (or i1R) EOS is probably the smallest flashlight that Olight has ever produced for the I Series (keychain).
    In keeping with the tradition of the previous EOS model (I3E), the I1R utilises the Philips LUXEON LED.
    Packaging & First Impressions
    This is what the light will come with as shown below.
    • The threads and o-rings were slightly lubricated. Threads were smooth and clean (no gritty feeling at all) – great for twisty lights.
    • Ample threads for a twisty light to remove any likelihood of the head unscrewing off from the body and dropping off by accident.
    • Anodizing of the light is uniform without any missing specs.
    • Pre-attached keychain split ring helps prevent the flashlight from rolling freely if left on its sides.
    • Scanning the QR code with your phone/tablet on the box's side would bring up the Olight I1R's product page.
    • Unscrew the head and remove the yellow insulating film inside before first operation of the flashlight.
    Front:
    Back:
    Sides:
    Top:
    Bottom:
    Box Contents:
    Quick Overview
    (Manufacturer Specifications)
    • Body Material: Aluminium
    • LED: Philips LUXEON TX
    • Battery Format: Built-in (non-removable) 80mAh 3.7V Li-ion Battery - most probably a 10180 Battery
    • Output & Runtime:
      • Low (5 lumens / 7h)
      • High (130 lumens / 20min) - output gets progressively dimmer as battery charge depletes
    • Max Beam Distance: 54m
    • Beam intensity: 730cd
    • Waterproofness: IPX-8 Standard
    • Impact Resistance: 1.5m
    • Dimension: 41mm (length) x 14mm (head/body diameter)
    • Weight: 12g (including battery)
    • Accessories Included:
      • 1*Built-in (non-removable) 80mAh 3.7V Li-ion Battery
      • 1*Micro-USB Cable
      • 1*Split Ring
    • MSRP: ~$17
    UI (User Interface)
    UI for this light is great for keychain or pocket duty due to its ease of operation.
    Switching ON and OFF is done by twisting the head of the light, so no momentary activation is possible.
    Twist the tail clockwise will activate LOW and twisting further clockwise will activate HIGH. Twisting the tail anti-clockwise will deactivate the light. These instructions can also be found on the tail of the flashlight.
    All twisty activation of the light can be easily done with one hand.
    There is no STROBE or SOS (blinky) modes for this light.
    Form Factor
    The light is extremely small - so much so that it could even disappear from view in a clenched small sized hand. Owing to its light weight and size, it will slip into a pants coin pocket, keychain or any place you would like to carry it and you wouldn’t notice it is there till you actually need it.
    Due to the ample "knurling" on the head and tail of the flashlight, it can be activated with one hand easily, even when wet or with gloves.
    The light is unable to tail-stand by itself due to the protrusion of the split ring attachment point.
    Charging Process
    With the provided Micro-USB Cable, the battery was charging at 0.08A.
    The flashlight is not capable of operating on any mode when charging.
    The RED indicator depicts charging in progress and GREEN indicator depicts charging has completed.
    Beam Style/Beamshots
    For this light, the spill, corona and hotspot is somewhat predictable due to the TIR (Total Internal Reflection) optics. The LED is fully covered under the TIR optics. With the LED used, the beam is still sufficiently “throwy” for recognizing items in the up-close to near range distance.
    The above beam profile is a rough interpretation of what is seen when white wall hunting. The beam has a wide circular hotspot with slight corona that fades out to a fairly wide usable spill. There are some beam artifacts in the beam when whitewall hunting but not visible in real world usage.
    All of the beamshots taken below are done so with the following camera settings (LOW: 1.3 sec, F3.5, ISO100, 5000K WB and HIGH: 1/3 sec, F3.5, ISO100, 5000K WB).
    Some pictures have been adjusted slightly to depict as close as to what is seen in real life. The distance of the light from the door is 4.6m.
    Control shot:
    LOW (5 lumens):
    HIGH (130 lumens):
    Mode (Output) Spacing
    Mode spacing appears to be progressively brighter to the eye and the modes are well spaced enough to be able to know which mode one is currently in. With that in mind, TLR tend to view mode spacing as battery life indicators (amount of runtime left) rather than the specific output (lumens).
    It would be nice if Olight would incorporate a MOONLIGHT mode to one that is actually at moonlight level (sub-lumen or 1 lumen) for those bedtime runs or during which having 5 lumens is still too bright for the night-adjusted eyes. However, 5 lumens is about perfect for up-close usage for all other occasions.
    Tint & CRI
    Olight did not disclose the tint (color temperature) and/or the CRI (Color Rendering Index) for the LEDs used in their light. For this light, a guesstimate would be in the 6000K and 70CRI ballpark.
    There are tint shifts throughout the beam profile. The hotspot is cool white whilst the corona possess a slight yellow-green tint; and the spill having a slight purple tint.
    This is however, not as noticeable in real life.
    Waterproofness
    The light was subjected to warm water submersion, followed by cold water submersion and left under room temperature running water tap whilst running on HIGH.
    No signs of water intrusion in the head or body was seen.
    Lockout Capability
    Being a twisty light, it has no electronic lockout but mechanical lockout is possible as needed.
    A quarter turn (anti-clockwise) of the tail from OFF will enable mechanical lockout.
    Scale Comparison (Ruler)
    Summary
    To sum up, we believe that the most important part of any review is if given the chance to purchase the same light for our own EDC or to gift to our loved ones out from one's pocket (wallet), would we still do it?
    For this light, it is a definite YES if the built-in (non-replaceable) battery is not an issue for your usage.
    The simple to use twisty UI and great for up-close usage beam profile provided by the TIR optics are all plus points for the i1R.
    However, the usage of the non-replaceable battery might be seen as a disadvantage for some. For others, it means that this flashlight is pretty much gift set-ready for their friends and/or loved ones; especially at its price point.
    Here is a bonus size comparison with some of the other small sized flashlights that we recommend as well.
    From Left to Right: Fenix E01, Olight I1R & Olight S1 Mini Baton.
    As with all gears, two is one and one is none.
    Stay safe,
    The Lite Review
    Disclaimer: Light was provided for by Olight (manufacturer) for this review. No other compensation was provided.
    Where to Buy Links
    Click HERE to check out where to get this light.
    Our Latest Reviews
    • Click HERE to view the latest Flashlight Reviews.
    • Click HERE to view the latest Reviews.
    The Lite Review (click for my Review website!)
    Flashaholic mightysparrow's Avatar
    Sep 2006
    Palookaville, USA
    Default Re: [The Lite Review]: Olight I1R EOS Review
    Nice review - thanks for posting it.
    "However vast the darkness, we must supply our own light." -- Stanley Kubrick
