EAGTAC
Results 1 to 3 of 3
Thread: Review: Olight I1R (1x10180 micro USB rechargeable EDC-Keychain)
    Flashaholic Budda's Avatar
    Nov 2009
    Italy
    Default Review: Olight I1R (1x10180 micro USB rechargeable EDC-Keychain)
    I received the Olight I1R from Olight for the Review.
    The I1R is a new keychain – compact EDC light from Olight. It features a Philips LUXEON TX Emitter, in a small TIR optic, powered by a 10180 battery rechargeable via micro USB.
    The I1R comes in this very nice sealed package
    The light is nicely presented as you open the box, and under the light there are the cable and the user manual.
    The I1R is very small, 14x41mm, and weights next to nothing (a tenth of grams).
    Here is next to one of the small BIC lighters
    Small but bright
    On the tailcap, which allows tailstand, there is written the simple UI: twist partially to turn the light on at
    low mode, fully tighten the head on the body to activate high mode.
    Untwist the head to remove it from the body, showing access to the micro USB port for charging.
    Don’t forget to remove the plastic spacer that insulates the light.
    When charging the light, under the white space on the head a red LED will turn on, and when the charging is complete, the light will turn green.
    Output and runtime
    Beamshots
    At 1 meter from the wall
    The beam is a good beam for EDC purposes. Big bright spot that fades in the spill.
    My thoughts
    The light is well built and finished.
    These 1x10180 lights are very useful in my opinion: they are so compact that you forget about them, and still pack a good power and have a decent runtime, considering the battery.
    Compared to other 1x10180 lights of the same price range, this I1R has a different construction (the recharging port space is not made out of the threads, but is in on the shaft of the light.
    This allows for a cleaner operation, as the port will not get any grease or other stuff that might get in the threads, and the o-ring still allows waterproofness of the port.
    Another difference is that the 80mAh 10180 battery is not easily removable: you have to disassemble the light to access it.
    The body and the head have some milling that helps the grip during the use of the light.
    The simple, well known UI, along with a nice realization and a curated packaging might make of this light a nice simple gift.
    I’d like to see this light come in a NW version.
    Thanks to: AntoLed for the tripod, camera help, luxmeter.
    Flashaholic chorlton's Avatar
    Sep 2008
    England
    Default Re: Review: Olight I1R (1x10180 micro USB rechargeable EDC-Keychain)
    Nice review! Can you give a tint comparison with a cool xpg? What is the neon disc in the picture of th light opened?
    Flashaholic* MikeSalt's Avatar
    Jan 2007
    Stoke On Trent, Staffordshire, UK
    Quote Originally Posted by chorlton View Post
    That's just to keep the light locked out until the owner removes it.
