SunwayLED
Results 1 to 6 of 6
Thread: Are 4 X AA NiMh =, <, or > than a single D-Cell NiMh
    Default Are 4 X AA NiMh =, <, or > than a single D-Cell NiMh
    Which are better for run times, max power etc? 4 X AA's or a single D-Cell? I've seen D-Cells being sold with as low as only 2200mah...
    Flashaholic* MikeSalt's Avatar
    Jan 2007
    Stoke On Trent, Staffordshire, UK
    Default Re: Are 4 X AA NiMh =, <, or > than a single D-Cell NiMh
    You'll probably find that the D cells with such low capacity are actually an AA cell in a D sized wrapper, which explains the low capacity.
    The highest capacity D-cells I've seen are 10,000 mAh. Since it is trivial to find AA cells over 2,500 mAh, I suspect that 4 x AA cells may be the way to go. There just hasn't been as much development money spent on C and D cells because they are not as popular as AAA and AA.
    The only single D-cell light I've seen recently is a $5 Everready light rated at 7 lumens.
    10,000 mAh for a D-cell sounds about right based on volume, but I don't know if they actually achieve their advertised rating and how they perform under load, because I haven't looked for independent testing on them.
    With well-tested brands like Eneloops for the AA options, we know the performance under load is good to 3 Amps or more, and there's several lights available from decent quality manufacturers like Fenix, Thrunite, Nitecore, and Manker in the 4 x AA form factor.
    Flashaholic* fivemega's Avatar
    Jan 2003
    California
    Quote Originally Posted by lightseeker2009 View Post
    4AA in 1D M*g will be 4.8V, 2500mAh (12 Wh)
    Single D in 1D M*g will be 1.2V, 10000mAh (12 Wh)
    Single 26650 in 1.2 M*g 3.7V, 5800mAh (21.46 Wh)
    2P 18650 in
    Double Parallel 18650 1.25 M*g 3.7V, 7000mAh (25.9Wh)
    Quote Originally Posted by fivemega View Post
    2P 18650 in
    Thank you.
    This puts it nicely in perspective.
    So if you own a 4AA light, you are basically owning a 1D cell light
    From from what I see also above. 4AA is almost the same as a single 18650?
    Jun 2014
    Thank you.
    Roughly, yes, as far as energy storage goes.
    4xAA gives you the option of higher voltage than 1xD (and correspondingly less capacity) if you want it. This can be very useful for high-output lights, and for designing lights that don't need boost drivers.
