Wuben
Results 1 to 9 of 9
Thread: Aaa keychain light?
    Default Aaa keychain light?
    My old Fenix l0dce-q4 is still going strong but itís definitely dated led tech. I could do an emitter swap but Iím in my last o ring and the keychain ring is almost worn through the aluminum. Considering hunting for a replacement.
    Ideally, it would be a low-high 2 mode twisty starting in low every time. 10lumen or there about. High mode for max output possible with around 60min run time maybe a little less. AAA only. Also ipx8 waterproof minimums. Would prefer something that wonít be phased by
    A canoe trip... or a trip through the washer.
    Any thoughts? Iím very tempted by the SF
    Titan but at $60 there has got to be other competition with either better specs or lower cost.
    *Flashaholic* this_is_nascar's Avatar
    Mar 2002
    Gloucester, New Jersey
    Default Re: Aaa keychain light?
    Fenix E05 2014 Edition?
    ... it's not what you take when you leave this world behind you, It's what you leave behind you when you go.
    Flashaholic* MikeSalt's Avatar
    Jan 2007
    Stoke On Trent, Staffordshire, UK
    Quote Originally Posted by this_is_nascar View Post
    Good shout, it's one more mode that the OP was looking for, but the budget is right, the mode order is right, it's a twisty and I know it's a great light from personal experience
    Jan 2007
    Only downside of the E05 is that the XP-E2 is a dated emitter itself. I'm going to throw the Reylight Copper Pineapple AAA into the ring. The Nichia 219c emitter will give a much nicer light than the Cree. Ignore the mode order on BangGood, I have checked elsewhere and it is Low-Mid-High.
    Quote Originally Posted by MikeSalt View Post
    Yeah I noticed that about the e05 also. If this l0d crapped out and I needed to replace now it would make sense though Iíd likely just fill in with a new e01 or i3e for a budget measure.
    That reylight looks like a great option! The bail for attaching to a key ring looks suspect though. Is it durable?
    Looking through Banggood I found another interesting options. IPx8 rated, nichia 219c and lo-m-hi twisty. Under $10. Great reviews. Pulled the trigger on an Astrolux A01 nichia 219c. It'll be a while before it arrives but, depending on quality, *could* displace my trusted L0DceQ4.
    Jan 2007
    Quote Originally Posted by Buck91 View Post
    I've not experienced Astrolux myself, but if it works out, that's a great price.
    I'm sure you can find a cheaper AAA than the Titan+... but mine has been EDC for two years now. No regrets. I'd buy another.
    I have some experience with the A01. Great light with a nice LED, but I'm not too convinced of durability. It's also a larger design than other AAA keychains.
    I'd toss in the Thrunite Ti3 XP-L version. Firefly-Low-High, twisty, and durable. I had an XPG2 version on my keychain for a long time, displaced by the smaller copper Olight i3e. You might be able to find a NW floating around, they also had a NW Titanium version at one point too.
