^^^ Search eBay for "5A Adjustable CC/CV Display Step Down charge Module LED Panel Voltmeter Ammeter", e.g.
here's one for $5.82 with free ePacket shipping to USA (typically arrives in 10-15 days). Below are the specs.
Note that they don't explicitly mention the
SBS (Smart Battery System) capability. I found it only by chance when I noticed the final photo (posted above). From that it was easy to figure out how to use it. For under $6 it's a steal with all that functionality. It will work with most all modern laptop batteries (as well as many other devices) since they employ the ubiquitous SBS standard.
Applications
Constant current and constant voltage
battery charger for various type of battery (NiCad, NiMH, LiPO, Lead-Acid, etc)
Work as a power supply with current limit, can test a circuits in safety condition
LED Driver
Features
Adjustable voltage & current output
Voltmeter & Ammeter Display
Charging and fully charge led indicator light
Serial connection for voltage & ampere reading
Screw terminal for wires connection
Specifications
Module Properties: non-isolated step-down (BUCK) switching regulator
Input voltage: DC 5.0 - 32V
Output Voltage: Adjustable 0.8 - 30V DC (Input must 1.5V greater than output)
Output Current: Adjustable continues 4A, max. 5A (Heat sink required)
Measurement Accuracy: ±0.1V (To ensure the accuracy, keep the input above 4.5V)
Conversion efficiency: Up to 95% (Output voltage higher, the higher the efficiency)
Output ripple: 50mV (Max) 20M bandwidth
Minimum dropdown voltage: 1.5V
Switching Frequency: 300KHz
Display: Dual 4 digit – 0.28" Digital tube
Operating temperature: Industrial grade (-40 to +85°C)
Size: 51mm x 26.3 mm x 14mm
TTL Communication
Baud Rate: 9600 Bps
BB CC ADDR 00 XX XX CRC (current return command)
BB CC ADDR 01 XX XX CRC (voltage returns to the command)
BB CC for the header (2 bytes)
ADDR for the module address (1 byte)
00 to read the current command (1 byte)
01 is a read voltage command (1 byte)
XX XX arbitrary value (2 bytes)
CRC CRC checksum (1 byte)
from
http://qqtrading.com.my/dc-dc-step-down-5a-xl4005-ampmeter-voltmeter-display-buck-converter
