Acebeam
Results 1 to 4 of 4
Thread: GE Nighthawk Xenon H11
    Default GE Nighthawk Xenon H11
    How do they look. 5 feet away. I only placed one bulb on the left side so far.
    Here is how they look next our ‘17 CRV with stock halogens.
    25ft away bulb installed on both sides.
    Moderator Alaric Darconville's Avatar
    Sep 2001
    Stillwater, America
    Default Re: GE Nighthawk Xenon H11
    Photos can't often tell us a bunch about headlamps, but I'd hazard a guess that the CR-V has "long life" bulbs, seeing the color temperature difference that the auto white balance exaggerates.
    Quote Originally Posted by Alaric Darconville View Post
    What’s weird about the GE’s is that the left side seems stronger than the right side.
    Sep 2001
    Stillwater, America
    Quote Originally Posted by Crvrav View Post
    Swap the left and right sides. If the pattern stays exactly the same as it is now, then it's the lamp assembly, not the individual bulb. Foreign matter in the bulb seat on the lamp may also interfere with proper clocking and seating of the bulb, so first remove the bulb, check the mating surfaces, and reinsert. If it still looks unusual, then swap the left and right sides to see if they match.
