Fenix Outfitters
Results 1 to 4 of 4
Thread: Test/review of Sanyo UR18650FB 2400mAh (Red)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/review of Sanyo UR18650FB 2400mAh (Red)
    Official specifications:
    • Nominal capacity: 2400mAh
    • Nominal voltage: 3.70V
    • Charging: 2400mA to 4.2V
    • Maximum discharge current: 4800mA
    This is a old "high capacity" cell.
    The discharge curves tracks nicely, but the cell cannot deliver more than about 2C, i.e. about 5A.
    Conclusion
    This cell may have been a very good cell when it was made, but it is way behind a modern cell in both capacity and current.
    Notes and links
    Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Compare to 18650 and other batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Oct 2013
    USA
    Default Re: Test/review of Sanyo UR18650FB 2400mAh (Red)
    What calculation did you perform to get 0.23 ohms IR? That seems too high.
    *Flashaholic*
    Dec 2004
    Northern Virginia
    2400 mAh must have been hot what, about 7-8 years ago?
    ****** Malkoff Devices ****** “Learn to light a candle in the darkest moments of someone’s life. Be the light that helps others see; it is what gives life its deepest significance.” ― Roy T. Bennett, The Light in the Heart
    Oct 2013
    USA
    Quote Originally Posted by Gauss163 View Post
    No reply, so I will explain what I think is happening. The "How is the test done" link says that IR is calculated from the slope of the (first?) curve in the protection test, using the final 2A segment of the curve. But above this final 2A segment is far past the max current rating of the cell, i.e. it is between 12.6 - 14.6A, but the cell is rated at 4.8A max. If we calculate the slope at this max rating - say between 3A and 5A - then instead of 230 mOhms we get 110 mOhms - consistent with Sanyo's datasheet value for this class of cells.
    There are no widely-used standards for calculating and comparing IR. But surely it is more useful to report values measured in normal usage ranges rather than in abnormal ranges where cell is extremely overloaded so the IR increases greatly (e.g. over 2x in the above test).
