EAGTAC
Results 1 to 1 of 1
Thread: [Review] Nitecore TIP Cu ... 360 lm + Copper + USB Charging
    Arrow [Review] Nitecore TIP Cu ... 360 lm + Copper + USB Charging
    Hi All! FastTech sent me the Nitecore TIP Cu to test. The Cu is a new addition to the now wide variety of NItecore TIPs available. This time itís solid copper, a much coveted material for fashion and performance oriented EDCíers. Itís still the same specs as the previous versions but Iíll add my tests to plethora of info on this beauty.
    Product page: https://flashlight.nitecore.com/product/tip
    Overview
    Overall, this light is very easy to use, versatile 2-button interface, and has a strong output that doesnít step down at all. My only wishes would be to have electronic lockout and a more straight forward key ring accessory.
    Quick Specs
    Features
    Included
    • TIP Cu light
    • 3 key rings/clasp
    • Paperwork
    One thing to note is that the light does not come with a micro USB cable or a wall charger but pretty much any USB charger setup will do.
    Options
    The copper version of the TIP has only one LED option. There are many other options now for the TIP. There are 2 other base materials, ďmetallicĒ and ďSSĒ or stainless steel. For metallic, there are 7 body colors and cool and neutral LEDs available. For stainless steel, there are 3 body finishes but only cool LED available.
    Price
    Current price is about $37 USD but you can get it for only $30 from FastTech.com
    Look & Feel
    The general flat shape feels very stable and has great tactile switches which are easy to locate. The switches have a very audible click when pressed.
    The fresh out-of-the-box the shiny copper looks amazing but be warned that over time the copper will oxidize and finger prints may leave a semi-permanent mark.
    The clip itself works ok but trying to use it as a switch cover is a little bit annoying as you have to take the whole thing off to turn on the light.
    The overall, weight was more heavy that I was expecting.
    The key ring loop on the light is a double bar which is very strong. The key rings and clasp provided to attached to the light are a little confusing as to which one(s) should be used or what order they all go in.
    Optics
    LED specs
    The specs say the light uses one CREE XP-G2 S3 LED (pictured below) but I have a feeling that the LED is actually the XP-G3
    Beam Profile
    The light has a medium wide 30 degree FWHM beam angle. This is the angle at which light output has reached 50% of maximum. The total spill beam angle is about 90 degrees.
    Currently, these readings are strictly sensor recorded, and are not adjusted based on human perception of light.
    Tint
    Overall a bit cool plus: the spot has a faint purple, the corona is a some yellow, and there is a bit of a yellow halo at the edge of the spill. Below is the TIP on the left and the Nichia 219B on the right (in the Nitecore MT06MD)
    Output Levels
    Hereís a run-through of all the different output levels:
    <font color="#000000"><span style="font-family: Arial">
    Outdoor Beamshots
    All the pictures below are taken with the light in TURBO.
    Power
    Charging Tests
    The light charged in about 1 hr 50 min and I calculated the capacity to be 600 mAh, which is more than the advertised 500 mAh.
    Indicators
    The light has a red/green power indicator. I believe that the red indicator is now a little bit brighter than before which will help when checking the light during the day.
    Charging
    When charging, the light will be steady red; when complete the light will be steady green.
    Battery Check
    To check the battery level, from off, single click the mode button; the indicator light will blink 3 times for battery greater than 50%, 2 times for battery less than 50% but more than 10%, and 1 time for below 10%.
    Low Power Warning
    When the light is on and the battery is low, the light will blink red
    One neat thing is that the light can run while being charged at the same time!
    Performance
    Runtimes
    The caveat to start here is that as long as you donít let go of the turbo since the start, it will stay in turbo without dropping down, but if you turn of and on the light, the thermal protection kicks in and you canít access turbo until itís cooled. The turbo lasted about 26 min and over the next 6 min it dropped down to 10% with no turbo reset. When I tested a turbo reset at about half an hour in to the test, the light output dropped and would not fully go back to turbo.
    Temperature
    A max body temp of 146įF and out-the-front temp of 164įF was observed for starting in turbo with NO reset, this body temp is a bit hot for the usual Nitecore light.
    PWM Check
    There appears to be no significant PWM on any constant mode. For comparison, the third graph shows PWM varying from 0 to 120 lx on the LOW mode on the Nitecore R25 flashlight.
    Strobes
    No strobe.
    Flashing/Beacon
    No other modes.
    User interface
    The UI is very similar to Nitecoreís typical 2-button electronic switch interface which features shortcuts to ultra low and turbo. One thing to note is that the turbo can only be latched from the shortcut to turbo, it is not in the primary mode cycle, but still can be momentarily accessed. One thing that wish the UI featured was an electronic lockout function.
    Comparisons
    Nitecore has made a few different types of keychain lights but they are all a little different including the closest being the TINI.
    Conclusions
    Highlights
    • Good UI
    • Great material
    • Solid body
    • Can run while charging
    Comments
    • Would like an electronic lock out
    • Keychain accessory is a bit confusing
    • If you donít let go of turbo it gets pretty warm
    • Doesnít come with a USB cable
    • Plastic clip/switch cover is a little annoying to deal with
    Notes
    Disclaimers:
    • CivilGear Reviews received this product from FastTech.com for testing and providing an honest review.
    • CivilGear Reviews was not paid for writing this review.
    civilgear blog
