ultrarunner2015
- Joined
- Nov 23, 2014
- Messages
- 57
Hi;
2yrs ago I purchased 8 of the Powerex 2700 mAh batteries. These are not labeled Pro or Pre-Charged. Just Powerex.
I also purchased a Maha MHC-9000 smart charger, and have been using it exclusively since.
The first thing I did when I received the batteries was to run them on the Break-In cycle.
The capacities reported at the end of the cycle ranged from 2501 to 2555, which is within the spec for the 2700 mAh batteries.
I have charged the batteries at 500mA, which is actually lower than the recommended minimum of 0.3C, but that has never been an issue.
I also use 500mA for the discharge rate as well.
Every few months I have run the Refresh/Analyze cycle on these batteries.
I see the capacities dropping gradually over time; this is to be expected.
These batteries were used regularly (every night) in my Diamond LED headlamp for the first year, then not much at all for the next year, but I ran them through the Refresh/Analyze cycle every few months while in storage.
Then, in June this year, I returned to using the batteries on a daily basis.
The capacities are down to a range between 2230 and 2275, but one battery of the 8 is at 2338.
All the while I have been charging (and discharging in the charger) at the 500mA rate.
The other day I did some reading on the Maha website, and learned that the optimal charge rate is 1300 mA (0.5C) and discharge of 700 mA.
So I decided to run 4 of the 8 batteries through the Refresh/Analyze cycle using those figures.
The result was significantly lower capacity than at the 500mA charge / Discharge rate.
The range was 2022 mAh to 2075 mAh with the one battery (the same one that has always had a higher capacity) reading 2194.
So I'm seeing a drop of 200mAh after running them through R/A at the higher rate.
After this result, I ran them again through the R/A cycle, but lowered the rates to 800 charge 500 discharge. The result was pretty much the same as it was for the previous - higher rate cycle. One battery actually read "HIGH" when I first put it into the charger for the R/A cycle after the higher current one, so I ran them all through Discharge before running the R/A at 800/500 mA.
I decided not to run any more cycles on these batteries for now; just use them in the headlamp until they drop below a comfortable brightness - which is usually when the battery indicator on the headlamp turns red when the high brightness beam is on.
My thinking is that the higher charge rate may have temporarily re-formed the batteries so they have a lower capacity. I have no idea why this would happen - or if that is actually what happened; it's just speculation at this point.
So the next time I put them into the charger, I think I am going to run them through the Break-in cycle.
Perhaps I should even allow them to discharge to a lower level (in the headlamp) before doing this. Since the headlamp is electronic, it will never allow the batteries to go completely dead - unless one is weak and does go to 0V before the other are low enough to shut the headlamp off.
The discharge cutoff voltage of the MHC-9000 is 1.0V. Is this low enough? Maybe I should build myself another discharge circuit that could bring the batteries down to a lower voltage. Or perhaps hack the MHC-9000 so it will do that.
Any ideas?
Thanks
FW
Any ideas?
Thanks
FW
