Listman 20700 3400mAh (Yellow)
Official specifications:
  • Battery Capacity (Mfg Rated): 3400 mAh
  • Battery Chemistry: IMR - LiMn
  • Battery Feature: Rechargeable
  • Battery Form Factor: IMR 20700
  • Battery Rated Voltage: 3.7 V
This is a high current 20700 battery.
The two cells tracks fairly well and can deliver nearly 30A, I get about 3000mAh from them to 2.8V
At 30A the cells gets rather hot.
Conclusion
This battery is designed for high current and do that fairly well, but specified capacity is a bit optimistic.
Notes and links
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
Compare to 26650 and other larger batteries
