[Review] Rofis MR30 (XHP35 Hi, 1x21700, micro-USB charge and powerbank)
bmengineer
Ontario, Canada
The Product
Rofis MR30
Today I'm taking a look at the Rofis MR30. Rofis already sent me their MR50, which I reviewed here, and I liked it overall. In that review, I said the light was a great powerbank and a decent flashlight. Now GearBest was nice enough to send me over one of Rofis' other lights from this series, the Rofis MR30.
This light has a lot in common with the MR50, so if you've read that review some of this one will sound pretty similar as well.
Spoiler
This product is really an improvement over the MR50. It has a slimmer body, and a pocket clip, which make it overall more pocketable. The LED chosen for this light, the XHP35 Hi, gives a clean beam that I like a lot. Compared to the XHP50.2 in the Rofis MR50, this light manages to get more throw out of a smaller head, even with the slight reduction in output. For me, this is the best flashlight/powerbank I've used so far, and I like it a lot. This will be my new go-to backpack EDC.
The UI of this light is the same as the MR50, which is to say there's plenty of room for improvement - it has no moonlight or very low mode, and not even a shortcut to the lowest available mode. I would love to see an update to the way that the modes on the MR50 are accessed.
On the powerbank side, I would love to see an upgrade to USB-C in the future. Micro-USB is becoming a bit dated in general, but I think a product like this would have a special benefit to using this newer protocol. USB-C supports both power in and out, which would eradicate the need to carry around a separate dongle just for powerbank use.
Size
I measured this light at 121.2 mm long, 29.7 mm in diameter at its widest point, and 25.8 at its narrowest. Despite the larger cell and slight increase in girth, this is extremely similar in size to the Convoy S2+ I use as a benchmark in many of my reviews. The Convoy is far from the smallest light, but even so I really like how compact the MR30 is.
Convoy C8+, Rofis MR50, Rofis MR30, and Convoy S2+
Build
Bezel and head
Starting at the head, this light has a smooth bezel that holds the textured reflector in place behind the window. The bezel on my sample is thread-locked, and whatever substance Rofis uses to hold their lights together must be made from mithril - I have never managed to unscrew something they didn't want me to. Great news for durability, less so for modability. The bezel has the usual "hot" warning etched into it above the button, along with a serial number.
Head and button
Below the bezel, the remainder of the head end of the light has an octagonal cross section, with fins cut into two sides. The back-lit button is held in place with a stainless steel retaining ring. The button is slightly proud of its bezel, but I didn't have any issues with accidental activation. The hexagonal shape is enough to add some roll prevention to this light without increasing the diameter too much.
USB port cover
Opposite the button, a rubber dust flap protects the USB port from debris or light water ingress.
USB port and "knurling"
The tube is a separate part from the head of the light, unlike the MR50. Not that it matters in practice, because it's held in place with the same adamantium alloy used on the bezel. Below the button, the light has the model and brand etched into the anodizing. The same ribbing is present for grip as this light's larger brother had, a fine texture. It's not too grippy, but I do like the way it feels. Both ends of the body tube have grooves where the clip can be attached.
Tail
The tailcap is flat, which means the light has no issues tail standing. There's some more edges around the tail to make the cap easier to remove and further prevent the light from rolling around too much. There's also a lanyard hole in the tail of the light.
Tail threads and spring
Inside the tailcap, the threads are anodized and square cut. Backing the tailcap off slightly will physically lock out the light. The tailcap has dual gold colored tail springs serving as the negative contact for the light.
Positive cell contact
Inside the head of the light, you can see a single short spring that serves as the positive contact for the cell.
What's Included
Once again, Rofis ships the light in quality packaging with a little window to show the product itself. Inside, there's quite a bit of included kit.
  • Rofis MR30
  • Braided micro-USB cable
  • Braided USB-OTG cable (powerbank adapter)
  • Ballistic nylon sheath
  • Lanyard with installation helper
  • Two replacement o-rings
  • Replacement USB port cover
  • Paperwork
Ergonomics and Retention
As I mentioned above, the machining on this light isn't extremely grippy, but I still didn't have any issues keeping it in my hand. I'm happy with the switch location and the anti-roll features as well. The clip can be attached for either head down or head up carry. Neither attachment point gives it a true 'deep pocket' profile, but setting up the clip for head down only leaves about 2 cm sticking out of a pocket - I find that reasonable for a light of this size. The clip is good overall, but sticks out slightly where it attaches to the body, and can catch when engaging on a pocket.
Pocket clip profile
The light also comes with a sheath, which works equally well for head up or down carry, with the clip on or off. It's a nylon sheath with elastic sides, and a hook and loop flap to keep the light in place. On the back, there is one belt loop that's permanently sewn in place, and another that can be opened and is closed with a metal snap and a small patch of hook and loop fastener. There's also a metal D-ring at the top of the belt loops.
Light in sheath
Belt loop detail
The tailcap also houses a hole to attach a lanyard, and one is included in the package. The kit also comes with a stiff helper to make it easier to get the lanyard attached.
Modes and Interface
There are three main modes to this light, with claimed outputs of 20, 200, and 750 lumens, as well as a 1600 lumen turbo and hidden strobe modes. Operation is fairly simple - a quick tap will turn the light on to the last mode, and another turns it off. While on, holding cycles through the main modes. There are a few special actions that can be accessed as well.
  • From either on or off, double tapping the switch activates turbo.
  • A long press from off activates the location beacon, which flashes the indicator LED once every few seconds. In this mode, a single tap escapes to the normal 'off' state.
  • A longer press from off locks the light out, flashing the main LED twice to indicate it was successful. In lockout mode, pressing the switch lights up the indicator LED to remind you the light is locked out. Repeating the long press unlocks the light, and turns it on in low mode.
  • A quadruple tap from on or off turns on strobe mode. From strobe, a long press cycles to SOS mode.
The basic functionality of this UI is good, but I would really like to see long press from off as a shortcut to low. The low mode is claimed by the manufacturer to be 20 lumens, and I wish there was a lower moonlight mode as well.
Light Quality and Beam
This light uses a cool white XHP35 Hi. Cree's "Hi" series of emitters are favorites of mine, and this is no exception. There's no tint shift across the beam, and the textured reflector results in a beam with decent throw and a very usable profile. Rofis claims the throw at 335 m.
XHP35 Hi in an OP reflector
Power and Runtime
Testing was done with the included flat top 21700 cell, rated at 5000 mAh.
Runtime graph
The light has timed step downs, as advertised by the manufacturer. The MR50 had issues maintaining turbo for the specified time without stepping down, but this MR30 matches it's advertised runtimes without issue. I stopped both tests when the indicator LED was flashing red, but they were still about 10% relative output. As aggressive as the step downs are, I really like how flat the output is for the remainder of the run.
Charging and Powerbank
The charging cycle, as measured from the micro-USB port, shows a CC-CV curve, topping out at 1.75 A. When the charging was completed, the current dropped right to 0 without any trickle charging. While charging, the light can be used, but only as a single mode lamp - a single tap turns the light on, and another turns it off. There are no brightness modes, and long presses or other button actions don't do anything special. This works the same way without the cell in the light as well.
Charge curve
While charging, the switch light will be solid red. One comment is that the indicator has the same behavior if the cell is not in the light, so make sure you haven't locked it out before plugging it in. When charging completes, the indicator LED switches to green.
The powerbank of this light was tested at 2.0 A. The current delivery was steady, but the voltage sagged a bit as the cell drained. More thorough testing of the powerbank was done in the review for the MR50, which uses a similar cell and circuitry.
2.0A powerbank test
I would love to see a USB-C port used in future iterations of this light, as that would eliminate the need for this separate adapter. Note that power out will not work properly if the USB-OTG cable is plugged in to a device instead, i.e. the cable set-up is not reversible even though both ends are the same.
MR30 charging up the MR50
Summary
Pros:
  • Solid powerbank makes this a versatile device
  • Full kit with cell, charging, light, and a heap of accessories
  • Standard, replaceable cell - many products that add features like powerbanks use proprietary cells or seal them inside the device
  • XHP35 Hi was a great choice for this light, and makes a great beam - good throw, too!
  • Indicating switch
Cons:
  • Low is not low enough, and the UI should really include a shortcut to this mode
  • USB-C would be a much better choice of port for this light, but for now we're stuck living the dongle life
  • I'm not a fan of water resistance relying on the user seating the rubber flap properly
  • Aggressive step downs
